Stoichmetrics reading - need helps
Old Mar 30, 2004 | 03:58 PM
gamakichi77's Avatar
Default Stoichmetrics reading - need helps
right now i'm using Autometer air/fuel ratio meter for LED readings of my stoichmetrics. What i know accurate stoichmetrics reading is 14.7:1. how can i make sure that my stoichmetrics readings is at this ratio?....any meter or device i can measure it?.....instead of LED readings via meter.
Thanks.
Old Mar 30, 2004 | 05:44 PM
Kal's Avatar
Kal
Default Re: Stoichmetrics reading - need helps (acidburns_di)
wideband
Old Mar 30, 2004 | 06:19 PM
Kataku2K3's Avatar
Default Re: Stoichmetrics reading - need helps (Kal)
The Innovative LM-1 is an inexpensive wideband with display that seems to work pretty well for non-integrated wideband EMS's. With something like Hondata I would recommend a MoTeC PLM or a PLX device to tie a wideband into your system. Most of our cars run standalones such as FAST, MoTeC, and AEM which all have option for an integrated wideband, this makes tuning simple even when you're not on the dyno. As for A:F gauges (Autometer, Halmeter, etc.) there's nothing you can do to make them more accurate so I wouldn't even try. Just go with a wideband.
EDITED: fixing my bad grammar, I sound like an idiot...
Modified by Kataku2K3 at 8:13 PM 3/30/2004
Old Mar 30, 2004 | 06:34 PM
Kal's Avatar
Kal
Default Re: Stoichmetrics reading - need helps (Kataku2K3)
they make cool looking light effects
Old Mar 30, 2004 | 06:57 PM
thanks for your good info....
Old Mar 30, 2004 | 07:47 PM
92b16vx's Avatar
http://www.plxdevices.com
Old Mar 30, 2004 | 09:33 PM
i did go in thats websites....anyway, thanks for proposal...that devices need to go with MOTEC management
jetmech53
Apr 20, 2008 08:20 PM
99delsol
Oct 9, 2006 05:12 PM
Racermech
Apr 22, 2005 10:07 AM
azn98R
Feb 24, 2003 05:08 PM
TurBoXBirD16
Dec 2, 2002 06:22 PM
