Another short shifter vs. exhaust question, but this one's legit
Old Mar 30, 2004 | 03:56 PM
steronz's Avatar
Default Another short shifter vs. exhaust question, but this one's legit
Ok, so I just recently got my crx up and running. I installed a B&M short shifter while there was no exhaust, then drove it over to a muffler shop and had a cat-back system installed. I then put about 75 miles on it with no issues. But the B&M shifter is straight (compared to the slightly bent stock one), so I took it out and had it bent at a local shop. I put it back in tonight, and now it hits the exhaust pipe. Pretty bad, too. So can anyone think of what I screwed up this time around that would make it hit? The bend is above the pivot point and should have no bearing on how it's installed. Thanks.
Old Mar 30, 2004 | 04:20 PM
Nocturnal_Lude's Avatar
Default Re: Another short shifter vs. exhaust question, but this one's legit (steronz)
It sounds liek when they bent it that it may have tweeked the bottom end of it or do o the new curve up top, it forces the bottom oever when your shifting. Also, depending on the size of piping you have on that cat back, it could be bunching up on your shifter if your motor moves around from shoty motor mounts...if you wanted a curved short shifter why not buy it that way....they are made the way they are for a reason you know...hth
Old Mar 31, 2004 | 08:45 AM
bikerchris13's Avatar
Default Re: Another short shifter vs. exhaust question, but this one's legit (StripShowHatch)
I put a cheap short shifter in my rex with stock exhaust and the linkage hit in 5th and reverse so I cut about 1-1.5 inches off the linkage (the part that just hangs out on the end) and no more problems. Thank you Sawzall!
Old Mar 31, 2004 | 10:23 AM
crxtreme89h's Avatar
Default Re: Another short shifter vs. exhaust question, but this one's legit (bikerchris13)
Here's what you need:
I bought one from these guys and it's way better than ebay's short shifters. Don't buy one that looks like this:
If you want one of the ones from Evasive MotorSports visit this thread:
https://honda-tech.com/zerothread?id=741946
Old Mar 31, 2004 | 10:26 AM
jaydub's Avatar
sweet lookin piece there.
Old Mar 31, 2004 | 10:48 AM
EP3_05's Avatar
My short shifter hit my thermal exhaust. So I checked out the linkage and found that the shifter was hitting an extended part of the linkage and I just cut if off like the other guy did. That was 2 years ago and I haven't had a problem to this day. When you bent the shifter it may have tweaked the bottom so it now hits. Take a look under the car and see if you can modify the linkage so it doesn't hit.
Old Mar 31, 2004 | 12:22 PM
steronz's Avatar
Thanks for all the replies guys. I put the damn thing back together wrong. It's pretty embarassing, so I don't want to go into details. But everything works good now.
Old Mar 31, 2004 | 12:49 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steronz &raquo;</TD></TR><TR><TD CLASS="quote">I put the damn thing back together wrong. It's pretty embarassing, so I don't want to go into details. But everything works good now.</TD></TR></TABLE>
Don't worry, I am sure most of us know what you are talking about.
Old Mar 31, 2004 | 12:52 PM
Default Re: (jaydub)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydub &raquo;</TD></TR><TR><TD CLASS="quote">sweet lookin piece there.</TD></TR></TABLE>
It is pretty sweet. Best Shifter a guy could own!
*runs out and slaps a big wet one on shifter*
(not that kind of wet one) this kind--&gt;
However, the **** I bought is stainless steel too. Yeah.........it burnt me today.
Old Mar 31, 2004 | 12:53 PM
jaydub's Avatar
haha let's make **** jokes!
Old Apr 3, 2004 | 09:58 PM
spyz34's Avatar
Hey i just put my shifter in and it hit my exhaust. So i cut it with a sawsall until it didnt. Have any one else done this and had problems? I am still so surprised how much it reduced the throw. Now i have to be faster with the footwork to match the shifts.
Old Apr 3, 2004 | 10:56 PM
garlic jr's Avatar
Default Re: (spyz34)
a short shifter is only going to **** your transmission up your an idiot for even using 1.
Old Apr 4, 2004 | 07:45 AM
d357r0y's Avatar
Default Re: (garlic jr)
Care to explain?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garlic jr &raquo;</TD></TR><TR><TD CLASS="quote">a short shifter is only going to **** your transmission up your an idiot for even using 1.</TD></TR></TABLE>
Old Apr 4, 2004 | 08:03 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: Another short shifter vs. exhaust question, but this one's legit (crxtreme89h)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxtreme89h &raquo;</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerothread?id=741946</TD></TR></TABLE>
Why not? I bought a cheap eBay shortshifter and it works great, it was only 14.99. Shift throws are short, its a strong shifter, and best of all, it works.
Old Apr 4, 2004 | 08:44 AM
jaydub's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garlic jr &raquo;</TD></TR><TR><TD CLASS="quote">your an idiot for even using 1.</TD></TR></TABLE>
Should be "you're an idiot."
:irony:
Old Apr 4, 2004 | 09:09 AM
ijjz's Avatar
Default Re: Another short shifter vs. exhaust question, but this one's legit (LSVTEC 91 Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">Why not? I bought a cheap eBay shortshifter and it works great, it was only 14.99. Shift throws are short, its a strong shifter, and best of all, it works.</TD></TR></TABLE>
You are right. I have one my self and its worked great for over a year now. Also when I was at Summit I noticed they had like 5 different brands laying out and the DC sports one looks exactly identical so..
Old Apr 5, 2004 | 02:27 PM
Default Re: Another short shifter vs. exhaust question, but this one's legit (ijjz)
I definitely felt a major difference between the Evasive shifter and the Ebay shifter. More comfortable shifting and it seemed a bit quicker.
I think not. I think you know nothing really. It's ok though. You're probably in your 5th period class right now, typing away on the internet when you should be studying your punctuation.
Frost7177
Jan 17, 2007 09:29 AM
phu chai khao
Apr 16, 2005 02:58 PM
Suzukablue
Jan 30, 2005 07:04 PM
SPORT INJECTION
May 12, 2003 07:02 AM
SOHC_MShue
Jul 18, 2002 09:18 PM
