How does a racing clutch effect driveability?
Old Mar 30, 2004 | 03:23 PM
CrRexSiR's Avatar
Default How does a racing clutch effect driveability?
Ive got a 91 rex with a B16a1 and the stock y1 non lsd. It has an act stage 3 racing clutch on it right now, and the car seems to drive pretty harsh. Im not sure if there are other things that could effect it (my hasport mounts, stock bushings). If I were to put a more mild of a clutch in, would it make the car drive smoother and be a little easier to drive on the street?
Old Mar 30, 2004 | 03:28 PM
koto SM2's Avatar
Default Re: How does a racing clutch effect driveability? (CrRexSiR)
Yes, racing clutches usually have a more ON-OFF engagement rather than a smooth take-up. They also don't last long (that I've seen).
Old Mar 30, 2004 | 04:25 PM
Nocturnal_Lude's Avatar
Default Re: How does a racing clutch effect driveability? (koto SM2)
Stage 3 from what I have read it a RACE clutch...made for strack running or constant race shifting...there is a stage 2 race/street clutch that is less harsh and still very tight with grabbing power....but if you want the smoothest engagement with the least amount of harshness, go with the stage 1 street clutch or back to oem. It should help the drivabilty some and make the ride smoother between gears...do a search and see which clutches people prefer...it seems more often then not to be ACT, but everyone has a different preference...hth
em191
Sep 4, 2008 09:05 PM
ej--1socal
15
Sep 3, 2008 05:10 PM
spotscivic
29
May 15, 2007 07:18 PM
BSeries Racer
Mar 28, 2006 02:08 PM
Dumped DB2
Mar 6, 2004 05:15 PM
