buying used turbo(t3).exhaust housing cracks........
Old Mar 30, 2004 | 03:10 PM
thelate1's Avatar
Default buying used turbo(t3).exhaust housing cracks........
looking on ebay for turbo and a lot of them say that garret turbo exhaust housings are known for small hairline cracks.is this normal?should i stay away from this?info please!
thanxs
shawn
Old Mar 30, 2004 | 04:45 PM
thelate1's Avatar
Default Re: buying used turbo(t3).exhaust housing cracks........ (thelate1)
anyone?
Old Apr 2, 2004 | 01:54 PM
thelate1's Avatar
anyone with info on this? i wouldn't think that any kinda cracks would be good.a hairline crack is just the beginning of something larger right?
thanx
shawn
Old Apr 2, 2004 | 02:05 PM
trophy's Avatar
As long as its a small hairline crack I dont think it would cause any problems. Its something that just happens when air that hot is forced through something like that at such high volocities.
Old Apr 2, 2004 | 02:13 PM
thelate1's Avatar
Default Re: (trophy)
yeah, i understand.i just didn't know if there was a certain life span of an exhaust housing, when it starts to deteriate(sp?). i guess that also depends how hard it was used right?
thanx
shawn
Old Apr 2, 2004 | 02:53 PM
doucmehu's Avatar
Default Re: (thelate1)
If I was buying a turbo (which I'm not) I would probably not want to purchase something prone to cracks. There are a lot of choices.
I guess that didn't help much.....
Old Apr 2, 2004 | 06:37 PM
lazerus's Avatar
Default Re: (doucmehu)
most standard T3 internally gated turbine housings crack at the WG exit.
Its pretty common, and you wont have too severe side effects unless the WG hole is severely cracked, then you will have retarded boost response.
Old Apr 2, 2004 | 06:58 PM
thelate1's Avatar
Default Re: (lazerus)
so it's some what normal and is to be expected?
Old Apr 2, 2004 | 07:58 PM
lazerus's Avatar
did i studder?
machine4321
Jul 18, 2010 01:29 PM
turbohatch96y7
Jun 11, 2009 05:15 PM
csubucky19
May 19, 2009 12:22 PM
nytosc
Dec 18, 2008 09:01 PM
love2xlr8integra
Aug 11, 2004 09:43 PM
