Idle super low when stopped, almost kills.
Old Mar 30, 2004 | 02:44 PM
Joel_MN's Avatar
Default Throwing cel 45. Steps to fix?
See below..
thanks
Modified by Scribes at 5:19 PM 3/30/2004
Old Mar 30, 2004 | 02:55 PM
Joel_MN's Avatar
Default Re: Idle super low when stopped, almost kills. (Scribes)
just found something else on the forum, ill read that first..lol
Old Mar 30, 2004 | 03:14 PM
spaceman's Avatar
you could tighten the throttle cable a little and raise the idle rpm by a couple hundred or so
Old Mar 30, 2004 | 03:57 PM
Joel_MN's Avatar
Default Re: Idle super low when stopped, almost kills. (spaceman)
edit...
Modified by Scribes at 5:09 PM 3/30/2004
Old Mar 30, 2004 | 04:12 PM
SleepyHF's Avatar
could be TPS...check the voltage
Joel_MN's Avatar
OK, i just checked and its throwing a cel 45.
System Too Lean or Too Rich malfunction in the fuel monitoring systems
cspeedracing.com
What steps do you take to fix that? I mean, what is something to at first, or the most obvious.
Thanks
Old Mar 30, 2004 | 04:28 PM
Joel_MN's Avatar
Default Re: Throwing cel 45. Steps to fix? (Scribes)
ttt
Old Mar 30, 2004 | 04:39 PM
SleepyHF's Avatar
ok....if you are running really lean...your spark plugs are probably too cold...not really sure on the rich part, somebody lemme know if I am correct...
Old Mar 30, 2004 | 04:50 PM
Joel_MN's Avatar
Default Re: Throwing cel 45. Steps to fix? (ConfusedHF)
thanks, so i should check my plugs, see whether im running rich or lean, and go from there.
I thought i heard that an 02 sensor, the secondary one, could throw off the a/f reading if it wasnt in or not working, and the ecu, or fpr or whatever, would send more or less fuel. In which case, can it be disabled.?
Old Mar 30, 2004 | 05:07 PM
SleepyHF's Avatar
well if you cut the wire from the o2 sensor..your car might bog out and run like ****. But first thing i would do is check your plugs...what kind are you running right now
SuM Honda
Jan 1, 2010 07:29 PM
LST2
Jan 20, 2008 06:37 AM
the.hamburglar
Apr 10, 2006 10:27 PM
Armed Ferret
Jun 28, 2004 10:00 AM
khcivic
Feb 11, 2003 06:37 PM
