clutch not catching / catching high
Old Mar 30, 2004 | 02:15 PM
nubb's Avatar
Default clutch not catching / catching high
well i finally let someone else drive my car (a buddy of mine with a WRX with a buncha mods). He drives it for a bit and beats it a bit to see if it's got any ***** (i dont know how to spell cahuna's <-- probably wrong lol).
So he tells me that when he drops the clutch it catches VERY high (which it does) and that when he hits the gas after shifting the flywheel (i think i dont know jack about how the car works but i think that is correct?) spins and doesnt catch for a while. is this common with the gsr? and if it is, if i just replace the flywheel will that fix it?
Old Mar 30, 2004 | 03:22 PM
escape2me's Avatar
Default Re: clutch not catching / catching high (nubb)
bump
Old Mar 30, 2004 | 03:48 PM
Heylookits shawn's Avatar
Default Re: clutch not catching / catching high (97 GSR)
sounds like your low on clutch fluid
Old Mar 30, 2004 | 04:47 PM
Fullthrottlegsr's Avatar
Default Re: clutch not catching / catching high (Heylookits shawn)
your clutch is slipping. get new one
Old Mar 30, 2004 | 04:50 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: clutch not catching / catching high (Fullthrottlegsr)
Try bleeding the clutch fluid before anything else. I know I have to bleed the clutch just right to get the feel of the clutch I want and for it to catch low.
Old Mar 30, 2004 | 04:55 PM
thegrayghost's Avatar
No its not common, but if you replace your clutch, i think you'll be in business. And no you do not replace the flywheel, just the pressure place and clutch
Old Mar 30, 2004 | 04:57 PM
Default Re: clutch not catching / catching high (thegrayghost)
by the way, how many miles are on the car and/or the clutch if you know? It might just be its time to go
Old Mar 30, 2004 | 05:27 PM
nubb's Avatar
only 33k miles and i'm pretty sure its the stock clutch and its been beat to hell. i will replace it soon.
lude98SH
Feb 21, 2006 07:28 AM
xunkn0vvnx
Mar 9, 2005 01:47 AM
t04ecvc
Apr 20, 2004 03:38 PM
b20civic
Feb 1, 2003 07:38 PM
