2.5" to 2.25" Test Pipe
Old Mar 30, 2004 | 01:40 PM
Heisdan's Avatar
Default 2.5" to 2.25" Test Pipe
I'm short on the money right now.. dont wanna buy a catback.. so I need a test pipe that goes from 2.5 to 2.25 inches.. so I can put my JDM header on .. (my other header has a slice through it from the accident so I can't wait and save money.. I need it on now
IDEAS?
kteller.com doesn't have what I need.. it does but the flanges make it so I can only go from 2.25 to 2.5 inches not the other way..
http://www.kteller.com/store/p...d=239
Kteller8 is telling me it might work .. opinions?
Modified by Heisdan at 6:04 PM 3/30/2004
Old Mar 30, 2004 | 01:47 PM
andrewasf77's Avatar
Default Re: 2.5" to 2.25" Test Pipe (Heisdan)
dave at sms has what you need
Old Mar 30, 2004 | 02:08 PM
JoshRambo's Avatar
I have a tets pipe thats is 2.5" through out.
It will fit fine. never gave me a porblem going from JDM to 2.25" exhasut
Make me an offer if you want it
Old Mar 30, 2004 | 02:09 PM
KTeller8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heisdan &raquo;</TD></TR><TR><TD CLASS="quote">
kteller.com doesn't have what I need.. it does but the flanges make it so I can only go from 2.25 to 2.5 inches not the other way..</TD></TR></TABLE>
i got a new one for you
turn it around.. our 2.25-2.5 can be turned around and now you have 2.5-2.25
Old Mar 30, 2004 | 03:21 PM
JeffS's Avatar
Default Re: 2.5" to 2.25" Test Pipe (KTeller8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KTeller8 &raquo;</TD></TR><TR><TD CLASS="quote">
I'm curious... how are you going to turn around a pipe that should have a 3-bolt flange on one side and a 2-bolt (with a flare) on the other?
This is the reason I haven't ordered from you. It seems like you only sell test pipes and cats with the same flanges on both ends -- and an email from you said the same thing.
Old Mar 30, 2004 | 03:42 PM
Heisdan's Avatar
up up
Maybe you could give me some pics that make more sense there Kteller.. cause it certainly doesn't make much sense to me from the pics I've seen on your site.. looks like the flanges wont work like that .. thanks
Old Mar 30, 2004 | 03:44 PM
Heisdan's Avatar
Default Re: 2.5" to 2.25" Test Pipe (JeffS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JeffS &raquo;</TD></TR><TR><TD CLASS="quote">
Where are your 3 bolts coming from.. an aftermarket exhaust or.. stock R?
Cause if I remember correctly mine only has 2 on the exit of the cat..
Old Mar 30, 2004 | 04:05 PM
KTeller8's Avatar
well it can come with any flange you want on it, you just to ask: not sure which email you sent, but i do those all the time, we get ppl who ask for special lengths and they want 2 or 3 bolt here or there..
if its listed thats not a problem..
reason being, there isnt a "set standard" to what is on it: half the systems have 2 and half have 3. it all depends on your downpipe, and exhaust system:
Old Mar 30, 2004 | 04:06 PM
KTeller8's Avatar
Cause if I remember correctly mine only has 2 on the exit of the cat.. </TD></TR></TABLE>
this is exactly what i am talking bout , you can only assume on a "stock" system once you replace anything, it all changes..
some ppl have 2 on both sides, some have 2 and 3 and osme have 3 and 2
Old Mar 30, 2004 | 05:02 PM
Heisdan's Avatar
So with "your system" the 2.25 to 2.5 will work is what your saying.. can anyone else back this up??? pictures would be excellent cause the site's pics do not show what you are saying to be correct
The flange on the right side isn't the same as the flange on the left side of the pic..
Old Mar 30, 2004 | 05:25 PM
done's Avatar
Default Re: 2.5" to 2.25" Test Pipe (andrewasf77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andrewasf77 &raquo;</TD></TR><TR><TD CLASS="quote">dave at sms has what you need</TD></TR></TABLE>
dave made me one for my spoon header .. very nice stuff he makes
Old Mar 30, 2004 | 05:31 PM
^jefs0ng's Avatar
Banned
You could just hit a muffler shop if you decide not to go with sms
Old Mar 30, 2004 | 05:49 PM
Bbasso's Avatar
Call Dave at SMSP just tell him what you have and he'll make what you need.
As simple as that- And the quality is
Old Mar 30, 2004 | 06:02 PM
KTeller8's Avatar
Default Re: (Heisdan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heisdan &raquo;</TD></TR><TR><TD CLASS="quote"> The flange on the right side isn't the same as the flange on the left side of the pic.. </TD></TR></TABLE>
you did say you needed the flanges different right?
i ll see if i cant get you a picture, you seem to be a visual person:
skunk2nr needed the same thing but 3" to 2.5
Old Mar 30, 2004 | 06:39 PM
Heisdan's Avatar
uhh.. its 2 bolts on both sides of flange.. thanks
Old Mar 30, 2004 | 06:46 PM
Mr.Fairlady's Avatar
Default Re: 2.5" to 2.25" Test Pipe (Gravity)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gravity &raquo;</TD></TR><TR><TD CLASS="quote">I have a tets pipe thats is 2.5" through out.
Make me an offer if you want it</TD></TR></TABLE>
Josh...you holding out on me???
you used it on yours??
yours throw a CEL?...let me know..I may be interested
Old Mar 30, 2004 | 07:29 PM
KTeller8's Avatar
edit:
same thing but for skunk2ner it was a high flow cat..
if you need pictures or more info.. you know who to find me, i am done here
Modified by KTeller8 at 1:31 AM 3/31/2004
Old Mar 31, 2004 | 03:55 AM
mrtrex's Avatar
Default Re: (KTeller8)
I use the vision straight pipe. Works fine with my jdm header and spoon exhaust.
Old Mar 31, 2004 | 08:11 AM
genetsang's Avatar
im curious... Skunk2nr has a obd2 gsr... and i dont see a o2 bung on the cat...
did he just unclip the o2 sensor for the cat?
Old Mar 31, 2004 | 09:47 AM
JoshRambo's Avatar
Default Re: 2.5" to 2.25" Test Pipe (Mr.Fairlady)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Fairlady &raquo;</TD></TR><TR><TD CLASS="quote">
yours throw a CEL?...let me know..I may be interested</TD></TR></TABLE>
Yeah its the last part of the car i own. I had in on the car wheni had teh JDM header on it.
its 17.5" long and is flanged for a JDM header and is 2.5"
Old Mar 31, 2004 | 10:18 AM
KTeller8's Avatar
Default Re: (genetsang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by genetsang &raquo;</TD></TR><TR><TD CLASS="quote">im curious... Skunk2nr has a obd2 gsr... and i dont see a o2 bung on the cat...
did he just unclip the o2 sensor for the cat?</TD></TR></TABLE>
he got the bung, it may just be on the other side and you not see it: but he did get one
Old Mar 31, 2004 | 10:36 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KTeller8 &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
I would definitely want some form of flexible joint at the header/cat connection, whether it be a the traditional donut flange or a braided flex-joint. Otherwise, stress on the system created by engine movement can't be absorbed, and will instead be translated to such things as the mounting bolts on the head.
Old Mar 31, 2004 | 11:45 AM
KTeller8's Avatar
Default Re: (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
I would definitely want some form of flexible joint at the header/cat connection, whether it be a the traditional donut flange or a braided flex-joint. Otherwise, stress on the system created by engine movement can't be absorbed, and will instead be translated to such things as the mounting bolts on the head. </TD></TR></TABLE>
yes sir, by his other post in the forums.. he i looking for a few answers on his flex section, before he adds that...
Old Mar 31, 2004 | 02:11 PM
JoshRambo's Avatar
this is what the one i have looks like
flared out at the end to fit the JDM header.
Old Mar 31, 2004 | 06:36 PM
SMSP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KTeller8 &raquo;</TD></TR><TR><TD CLASS="quote">edit:
Modified by KTeller8 at 1:31 AM 3/31/2004</TD></TR></TABLE>
Why is the heat shield on the bottom of the cat?
