dampener question
Old Mar 30, 2004 | 12:06 PM
RiCE On IcE 2's Avatar
Default dampener question
Will runing on a stiffer setting on the street shorten the life of the dampener when compared to running on a "lighter" setting?
Old Mar 30, 2004 | 12:37 PM
ZygSpeed's Avatar
Default Re: dampener question (RiCE On IcE 2)
I'd venture to say that it also depends on the stiffness of the spring used.
If the dampener is doing all the work then it might wear more quickly, if a stiff spring and stiff damper settings are used then I'd think it's working like it's supposed to and wear shouldn't be as much of an issue.
Old Mar 30, 2004 | 12:45 PM
Default Re: dampener question (zygspeed)
it's on the Tein type FLEX.. I think springs are 8-6? or 8-4 or something liek that.. so no the springs are not that stiff but I'm not setting the dampener that stiff just 6 in the front adn 8 in the back
Old Mar 30, 2004 | 12:54 PM
ZygSpeed's Avatar
I'm getting used to my Lowdowns and have been thinking along similar lines lately.
Not as much wrt wear, but just trying to select some appropriate settings for street use.
The problem seems to be that I might be bottoming out the fronts, or I need to add some more air to the tires (springs something like 350#/7K+ in front).
I'll be playing with the settings some more (only 1-5 on the Lowdowns), probably up the setting in the fronts some more.
I miss my Buddy Clubs, even with the 12K Front/14K Rear spring rates.
Old Mar 30, 2004 | 01:28 PM
so u dun think it'll lower the lifetime much by running it slightly stiffer? the road here can suck but i dun mind the stiffness and it keeps me awake lol
Old Mar 30, 2004 | 02:46 PM
mugenracer's Avatar
I'm in the same position, i have spoon coilovers with a straight spring (8front/6rear) and as with the lowdowns only have 5 settings, i have them set at 1 on front and back as our roads are crap and i found that even setting the fronts on 2 was too hard, i'm slightly worried that the shocks will wear out quickly like this and have considered raising the whole car 0.5-0.75inches (it rides just a few mil above the tyres at the moment) to give the shock more travel and not have it working as hard but i dont know if this will make a whole lot of difference.....
Old Mar 30, 2004 | 05:03 PM
Flux's Avatar
Default Re: (mugenracer)
Just my pet peeve.... they are not dampeners, they are dampers. They have nothing to do with water.
Old Mar 30, 2004 | 09:19 PM
DC2*Integra's Avatar
Default Re: (Flux)
i was wondering the same also. just to be safe i ride 1 front 1 back for daily driving
Old Mar 31, 2004 | 08:56 AM
Default Re: (DC2*Integra)
hmm so any answers for sure?
Old Mar 31, 2004 | 09:08 AM
Big Phat R's Avatar
Default Re: (Flux)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flux &raquo;</TD></TR><TR><TD CLASS="quote">Just my pet peeve.... they are not dampeners, they are dampers. They have nothing to do with water.</TD></TR></TABLE>
me too
Old Mar 31, 2004 | 09:53 AM
Default Re: (Big Phat R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R &raquo;</TD></TR><TR><TD CLASS="quote">
me too
and one of my pet peeves if people adding nothing to the thread.....
Old Mar 31, 2004 | 10:12 AM
Flux's Avatar
Default Re: (RiCE On IcE 2)
Part of being knowledgeable about a topic is the ability to articulate your thoughts and opinions clearly using the accepted vocabulary and semantics of the field. I was just trying to point out your simple mistake in the name of more precise communication.
Old Mar 31, 2004 | 10:20 AM
Default Re: (Flux)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flux &raquo;</TD></TR><TR><TD CLASS="quote">Part of being knowledgeable about a topic is the ability to articulate your thoughts and opinions clearly using the accepted vocabulary and semantics of the field. I was just trying to point out your simple mistake in the name of more precise communication.</TD></TR></TABLE>
I wasn't referring to you I was referring to the "me too" person..
KYLE.ECKERT
Suspension & Brakes
Jul 26, 2008 09:53 PM
sportyaccordy
Suspension & Brakes
Mar 18, 2006 08:57 AM
Type R1
May 29, 2003 08:00 PM
JDM DC2 R
Jan 24, 2002 08:48 PM
