Need help installing Cam Gear on 90 CRX SI
Old Mar 30, 2004 | 10:17 AM
90SICRX's Avatar
Default Need help installing Cam Gear on 90 CRX SI
I bought an OBX 5 bolt cam gear but it didn't come with any instructions on how to put it on. Could anyone point me either to a web site or maybe post how to install it? I could get professional help installing it but I'd rather do it myself so i can learn how, thats the only way to learn if you ask me.
Thanks for your time.
Old Mar 30, 2004 | 11:40 AM
Nocturnal_Lude's Avatar
Default Re: Need help installing Cam Gear on 90 CRX SI (90SICRX)
call obx and request that they email/fax you an instruction manual....most customer service is nice enough to do that and if your willing to put in the 30 secs it may take to type in "OBX" and slick on their website...you may find it online...be your own source of knowledge sometimes...put in some work before you ask for help...good luck...
Old Mar 30, 2004 | 11:48 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
set it to "zero" dergees...and put it on just like a stock one.
mark the timing belt location on the origional gear (tooth for tooth)
loosen bolt
slide the belt off
take old gear off
put the obx one and line up the belt with so that the marked tooth on the belt is in the correct position (tooth for tooth)
then tighten up the bolt...
Old Mar 30, 2004 | 06:13 PM
90SICRX's Avatar
Thanks guys that helps alot, i also found a section in my hayens manual about putting them on and taking them off.
But my next question would be what should i ddo about the timining? how do you know if you should Advance it or Retard it?
Old Mar 30, 2004 | 06:25 PM
Malgerus's Avatar
Default Re: (90SICRX)
You have an aftermarket cam? no? then set it to stock.
Old Mar 30, 2004 | 06:53 PM
90SICRX's Avatar
oh.....ok
Old Mar 31, 2004 | 05:22 AM
general rule of thumb:
retarding cam timing increases top end power
advancing cam timing increases midrange power
Old Mar 31, 2004 | 06:25 PM
90SICRX's Avatar
I'd need to advance it then becuase i have plenty of top end, I have like little to no low end and alittle mid.
Old Mar 31, 2004 | 07:51 PM
CRXDrew's Avatar
The stock camgear on my Z6 head has a woodruff key built it. And the OBX I got didn't come w/ one. Might wanna buy/find an extra.
By the way its the lil metal thinger that doesn't allow the gear to rotate on the cam
Old Mar 31, 2004 | 08:43 PM
y49crxsi's Avatar
Default Re: (CRXDrew)
Yeah, skunk2 was the same way, it had a notch the opposite way of the stock cam gear, so i went back to where i bought it, and they pulled a key out from another box, and SOLD it to me. 2 bucks, but what the hell, it should have came with it. I think all they do is sell a b-series cam gear by itself, and forget to throw in a woodruff key, becasue arent b-series cams notched out and not in like d-series?
Old Apr 1, 2004 | 06:05 PM
90SICRX's Avatar
Are you sure yours didn't come with a key? Mine did it was in alittle baggy underneather the cam gear, who knows what they do with them.
Old Apr 3, 2004 | 09:07 AM
Akiraboy's Avatar
if you start messing with timing I would recommend you have/get a timing gun, so you don't jack anything up.
Old Apr 6, 2004 | 06:46 PM
90SICRX's Avatar
Where does one look for a timing gun?
Old Apr 6, 2004 | 08:58 PM
brisk's Avatar
your local auto parts store
Old Apr 6, 2004 | 10:45 PM
kshymkiw83's Avatar
Default Re: (brisk)
don't go by a timming gun and not know how to read it either. You need to know how to read one, or else you'll sit there and flash the light and be like
Old Apr 6, 2004 | 10:47 PM
90SICRX's Avatar
lol thats good to know
smmcla
May 11, 2012 06:52 PM
rough_draft
Mar 29, 2005 04:52 AM
acatak
Jan 12, 2003 05:30 PM
REDBARON
Feb 26, 2002 11:12 AM
