B18B Head Oversized Valves question
Old Mar 30, 2004 | 09:07 AM
zilverz's Avatar
Default B18B Head Oversized Valves question
If one was to purchase oversized valves for there there b18b
Stock IN 31mm EX 28mm
Oversized IN 32mm EX 29mm
The valve ports on the head would need to be bored 1mm over correct? Anyone know if the valve seats would need to be changed as well ?
Old Mar 30, 2004 | 09:29 AM
ExospeedAMcrx's Avatar
Default Re: B18B Head Oversized Valves question (zilverz)
what pistons are you using? stock stil?
Old Mar 30, 2004 | 10:23 AM
zilverz's Avatar
Default Re: B18B Head Oversized Valves question (exospeedAMcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">what pistons are you using? stock stil?</TD></TR></TABLE>
No, Oversized 10:1 flattop
Old Mar 30, 2004 | 07:27 PM
zilverz's Avatar
bump
Old Mar 30, 2004 | 10:36 PM
zilverz's Avatar
anyone know ? bump
Old Mar 31, 2004 | 06:09 PM
zilverz's Avatar
anyone know the answer to this ?
Old Apr 3, 2004 | 10:22 AM
zilverz's Avatar
ttt
Old Apr 3, 2004 | 11:11 AM
Kendall's Avatar
It would be smart to change them anyway, just due to the fact that the head will be apart and you will have easier access to them.
Old Apr 3, 2004 | 12:05 PM
zilverz's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">It would be smart to change them anyway, just due to the fact that the head will be apart and you will have easier access to them.</TD></TR></TABLE>
would i need to use special oversized valve seats for 1mm oversized valves ?
Also does anyone know the answer to my first question? does the valve ports need to be bored 1mm over for the oversized valves ?
Old Apr 3, 2004 | 05:41 PM
Fkned's Avatar
Default Re: (zilverz)
no you don't have to replace the seats for a 1 mm over valve.Depends on who does the valve job as to weather they open the throat for the bigger valves.
Old Apr 3, 2004 | 08:55 PM
zilverz's Avatar
Default Re: (fkned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fkned &raquo;</TD></TR><TR><TD CLASS="quote">no you don't have to replace the seats for a 1 mm over valve.Depends on who does the valve job as to weather they open the throat for the bigger valves.</TD></TR></TABLE>
well i guess thats what im wantin to find out ... to benefit from the oversized valves ... should that bore the Valve passage over 1mm ?
Old Apr 4, 2004 | 08:37 AM
3gdude's Avatar
No need to replace the seats. If you get 1mm oversize valves, you will need to get a quality valve job done though as the seats will require quite a bit of cutting to make them bigger. I live in Jax too, near Regency, and I would recommend Zabatt's for the seat work. They have a Serdi valve seat cutting machine that can do a really nice job. It cuts all 3 angles at the same time, can precisely locate the new seat at the very edge of the valve, can cut each seat the same (duplicate), and requires no "lapping".......the only thing left will be blending the newly formed seats into the port area. Good time for a "mild" port job....3gdude
Old Apr 4, 2004 | 09:01 PM
zilverz's Avatar
Default Re: (3gdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3gdude &raquo;</TD></TR><TR><TD CLASS="quote">No need to replace the seats. If you get 1mm oversize valves, you will need to get a quality valve job done though as the seats will require quite a bit of cutting to make them bigger. I live in Jax too, near Regency, and I would recommend Zabatt's for the seat work. They have a Serdi valve seat cutting machine that can do a really nice job. It cuts all 3 angles at the same time, can precisely locate the new seat at the very edge of the valve, can cut each seat the same (duplicate), and requires no "lapping".......the only thing left will be blending the newly formed seats into the port area. Good time for a "mild" port job....3gdude </TD></TR></TABLE>
Thanks for the reply and recommendation Any idea what there going rate is ?
-[Lucky]-
29
Aug 5, 2007 09:12 PM
CivicVX94
Jun 5, 2006 06:08 PM
Jeter2NYC
Jun 27, 2005 06:34 AM
^AnDre^
Apr 4, 2005 04:11 PM
Charlie Moua
Jun 24, 2003 11:33 AM
