boosted b18b (noob question)
Hey, if you have a 96-00 civic sedan, with a b18b, will a bolt on turbo kit fit right in or will you have to modify the tubing?
Re: boosted b18b (JDMexican)
Thanks, and if you want to build up the head for more boost, what will you need???
Modified by JDMexican at 3:37 PM 8/1/2007
Re: boosted b18b (MDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MDM »</TD></TR><TR><TD CLASS="quote">just mess with the head meanwhile then go down to the block!! </TD></TR></TABLE>
But dont you need a stronger head for more boost?
thats what i said MESS WITH THE HEAD..
but u dont need anything for boost as long as u get a good tune at the right psi ur good to go!
you have the d16y7 SOHC non vtec, theres no power without boost, your better off swapping to a DOHC or buying a different car, unless u read up alot on boost
Re: (dawssvt)
since you stated that its a bolt on kit. im thinking that it should pipings should just bolt on too unless its a Home Made turbo where you gather the parts yourself?
Re: boosted b18b (95ProjectEJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95ProjectEJ1 »</TD></TR><TR><TD CLASS="quote">out of the 3 you have listed... the B18b1. </TD></TR></TABLE>
Thats the LS right? How do you get a LS/VTEC??
