B16A1
Old Mar 30, 2004 | 07:07 AM
jdmlife's Avatar
Default B16A1
Can you put a newer si tranny (hydraulic) on a B16A1? cause i dont want cable tranny
Old Mar 30, 2004 | 07:40 AM
SiRex91's Avatar
Default Re: B16A1 (jdmlife)
Only if you use HASport mounts and the HASport cable to hydro conversion (which my crx will eventually get in the future).
Old Mar 30, 2004 | 07:42 AM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
the answer is yes....with the cable to hydro conversion....hasport makes anything possible...hahah..
Old Mar 30, 2004 | 07:47 AM
nautica_t's Avatar
Default Re: (dgonzals)
go get an ITR lsd hydro tranny :D
or go with a ys1 cable lsd if your worried about the expense of getting the hydro kit.
Old Mar 30, 2004 | 08:16 AM
APEX CRX's Avatar
Default Re: (nautica_t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nautica_t &raquo;</TD></TR><TR><TD CLASS="quote">go get an ITR lsd hydro tranny :D
If you can find a good YS1 tranny still
Old Mar 30, 2004 | 08:19 AM
I3ackfire's Avatar
Default Re: (APEX CRX)
Could you guys let me know what the difference is between a cable tranny, and a Hydralic tranny is? I here soooo many people talk about them...Im not very knowledgable in trannies!
Old Mar 30, 2004 | 08:36 AM
civickiller's Avatar
Default Re: (I3ackfire)
the difference is a hydro tranny uses hydraulic lines to engage the clutch, a cable trans uses a cable to engage the clutch
Old Mar 30, 2004 | 09:33 AM
I3ackfire's Avatar
Default Re: (civickiller)
WOW, thanks for that great in depth explanation...
Old Apr 12, 2004 | 04:56 PM
Ape's Avatar
Ape
I would like to know aswell
Old Apr 12, 2004 | 10:54 PM
DC 2's Avatar
If you already have the tranny then go for it, another 150-200bux for the conversion and your good to go. Be careful if you plan on buying a JDM land tranny due to common grind problems and lack of part availability
Old Apr 12, 2004 | 11:32 PM
Mr_CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I3ackfire &raquo;</TD></TR><TR><TD CLASS="quote">WOW, thanks for that great in depth explanation... </TD></TR></TABLE>
theres not a whole lot more to it than that. one uses a cable to engage/disengage the clutch, and the other uses a hydraulic system. i'm sure theres probably a 20 pages description on one of those HowStuffWorks.com pages or whatever they are if you really want to read into it that much.
lakai_19
Oct 3, 2007 05:28 PM
mymeatb18"
Apr 20, 2007 09:18 PM
90 integra
Aug 7, 2006 09:26 PM
