Boosted RSX - How do you know when the motor is flooded?
Old Mar 30, 2004 | 04:23 AM
oojoe24oo's Avatar
Default Boosted RSX - How do you know when the motor is flooded?
I installed a Walbro 255 lph intank pump last night...The car ran fine at first but then all of a sudden when I went to go WOT the car would bog pretty bad and my rpms wouldnt move...Eventually the car died out...When I went to start up again it was real rough and wouldnt start.....If I let the car sit there for some time, it would start up but eventually stall out again....
Im thinking I flooded the motor with fuel...i figured the stock regulator would be able to handle the new pump, but I was also thinking maybe I need to change some numbers in the emanage values to let the emanage know there is a much larger pump in there....
Any ideas guys?
Old Mar 30, 2004 | 08:06 AM
BoostedDC5's Avatar
the emanage is not going to require you to change anything with the larger pump...there is probably a problem with one of the injecters pulsing higher than expected...I had that problem when I first put on the Greddy kit. You need to check the resistance of each injector....also I wouldnt adjust any of the emanage unless you are on a dyno. I did that one time and messed up some things...the car ran like hell....I would just check the injectors.....the problem probably lies there.
Old Mar 30, 2004 | 10:29 AM
Del's Avatar
Del
Default Re: (BoostedDC5)
kinda sounds like your running rich.. change your spark plugs and try to lean it out a bit...
thenumber24
Dec 3, 2011 02:15 AM
dc_5
Jan 5, 2009 06:00 PM
Boilermaker1
Honda Civic (2001 - 2005)
Nov 28, 2006 09:41 AM
todaCspec
Jun 19, 2002 12:48 PM
