VTEC launch - when?
Old Mar 30, 2004 | 01:55 AM
itr_18's Avatar
Default VTEC launch - when?
Hi,
Im thinking about when vtec should launch on mods like in ITR:
skunk2 stage2 cams
about 12.0:1 CR
ported & polished head
injectors 310 cc
spoon flywheel
custom intake
full exhaust (SS,Spoon), Toda header
+ AEM EMS or Hondata.
of course Ill choose best point when the car will be tuned on dyno but any suggestions?
Old Mar 30, 2004 | 03:12 AM
uNF$@#!'s Avatar
Default Re: VTEC launch - when? (itr_18)
Hi,
VTEC should "launch" whenever placed next to a nuclear missle.
VTEC should "engage" at whatever point it is set to engage on the computer.
Welcome
Tom
Old Mar 30, 2004 | 03:48 AM
GSRswapandslow.
Guest
Posts: n/a
3....2....1....V-TECCCCCCCCCCCCHHHHHHHHHH
skunk2's usually like an engagment anywhere from 5200-6100 from dyno's we've taken...depending on the build.
just take it to the dyno.....and run it with vtec set at like 9900 or disengaged...and then make a run wiht it set as low as you can....and see where the lines cross..and there's your point. the smoother the engagment the better.
Old Mar 30, 2004 | 04:04 AM
Jon D's Avatar
Default Re: (Ej6andslow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ej6andslow &raquo;</TD></TR><TR><TD CLASS="quote">
just take it to the dyno.....and run it with vtec set at like 9900 or disengaged...and then make a run wiht it set as low as you can....and see where the lines cross..and there's your point. the smoother the engagment the better.</TD></TR></TABLE>
What? I know this was a joke but what the hell does it mean. Is this like find the equilibrium or something? .
Old Mar 30, 2004 | 06:26 AM
itr_18's Avatar
I know its a bit stupid question but, maybe you just have any suggestions - it metters when its engaged
Old Mar 30, 2004 | 07:20 AM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: (itr_18)
Not a stupid question at all, but some people are going to jump on your non-mastery of english car-tuning phrases rather than give you an answer.
Old Mar 30, 2004 | 07:28 AM
itr_18's Avatar
Default Re: (Ross R)
Yeah I know hehe, some people are clever but not in the concret subject
But maybe there is someone...
Old Mar 30, 2004 | 08:40 AM
xx dc2teg xx's Avatar
Default Re: (B18C-Rsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C-Rsi &raquo;</TD></TR><TR><TD CLASS="quote">
What? I know this was a joke but what the hell does it mean. Is this like find the equilibrium or something? .</TD></TR></TABLE>
hes talking about the lines of using common sense to figure out the best vtec engagement point -- I think ~ not for sure
but a proven method is disengaging VTEC and running it on the dyno, then find you peak hp/power and use that point minus 200 rpms to suit where your vtecH should KICK in (sorry had to do that)
Old Mar 30, 2004 | 08:42 AM
Reid's Avatar
Global Moderator
Set VTEC at 1000 rpm, then do a pull.
Set VTEC at 8000 rpm, then do a pull.
Set VTEC engagement rpm to where the two lines intersect.
Old Mar 30, 2004 | 12:52 PM
GSRswapandslow.
Guest
Posts: n/a
wow, ppl are illiterate these days, huh?
Old Mar 30, 2004 | 12:56 PM
RTW DC2R's Avatar
Default Re: VTEC launch - when? (Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">Set VTEC at 1000 rpm, then do a pull.
Set VTEC engagement rpm to where the two lines intersect. </TD></TR></TABLE>
Hey Reid,
One thing I always wondered about this, is when setting it at 1000, should you do a couple different runs and change fuel settings for each run to try to get the most out of it while set at 1000? and do the same thing when setting it at 8000? Then set the xover point and tune the map from there? I guess theres probably different methods of going about it...
bluenc-87
30
Sep 13, 2014 09:38 AM
Na93hatch
16
Jun 8, 2012 08:29 AM
honda_ek9
14
Jun 7, 2009 04:42 PM
mdj_ge
Jun 29, 2005 09:28 PM
