Calculating Comp. ratio on b18c
Old Mar 29, 2004 | 08:33 PM
Reedy's Avatar
Default Calculating Comp. ratio on b18c
My question is how do I go about calculating the compression ratio on my JDM b18c. I know its 10.5:1 stock, but Im adding a Cometic head gasket in hopes of lowering it a bit so I can boost a little higher. Just would like to know what compression ratio I will be looking at after the head gasket is installed so Ill have a good idea where to stop with the boost befor I break all kinds of crap. BTW other than the parts mentioned above the motor itself is stock. Im only shooting for about 7 psi daily and about 10 or so at the track, but if I can go a little higher with this setup SAFELY I would like to.
Old Mar 29, 2004 | 08:39 PM
mmuller's Avatar
Mad Scientist
Default Re: Calculating Comp. ratio on b18c (Reedy)
here we go:
http://www.c-speedracing.com/h...c.php
just enter hg thickness
Old Mar 29, 2004 | 08:40 PM
N1 Andy's Avatar
R.I.P. Andy
Default Re: Calculating Comp. ratio on b18c (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">here we go:
just enter hg thickness</TD></TR></TABLE>
couldnt have said it better.
Old Mar 30, 2004 | 10:02 PM
Reedy's Avatar
Nice, used that site when I did my swap. Thanks guys.
cyko4374
Oct 23, 2006 12:12 PM
jtracing919
Jan 26, 2006 12:15 AM
HT Chaplain
Dec 20, 2005 07:37 AM
EKP72
Sep 30, 2005 04:26 PM
hybridEj6
Sep 29, 2003 05:27 PM
