how do i tighten up the gas pedal???
Old Oct 24, 2001 | 01:26 AM
Ch33se's Avatar
New User
Default how do i tighten up the gas pedal???
i know some of you have talked about it before and i did do a search but no luck. please if you can let me know in details for i am not very good with these things. thanks
Old Oct 24, 2001 | 01:53 AM
ThePunk's Avatar
Default Re: how do i tighten up the gas pedal??? (caliItr)
You don't tighten the gas pedal. You tighten the throttle cable. (At least remove the slack from the cable). This is done from inside the engine compartment.
Old Oct 24, 2001 | 04:18 AM
B18CXr's Avatar
12mm open end wrench.
Old Oct 24, 2001 | 04:50 AM
BoM's Avatar
BoM
Default Re: how do i tighten up the gas pedal??? (B18CXr)
dont' over tighten, your idle can raise if its too tight, cause the TB butterfly plate is slightly open
maxogsr
Jun 30, 2013 03:32 AM
VietCloud7
May 6, 2008 04:46 PM
Yeung
Jun 3, 2004 09:12 PM
hatch808
Dec 31, 2003 05:25 PM
Cat
Sep 30, 2002 06:48 AM
