what can I expect with this setup?
Old Mar 29, 2004 | 08:10 PM
N1 Andy's Avatar
R.I.P. Andy
Default what can I expect with this setup?
my current project is about 70% done and it consists of the following.
-B18A1 stroke/stock bore
-JDM B16A pistons
-Stock GSR Head with some ctr or 01R cams & a skunk mani in the future
-1 layer oem head gasket
-shitty usdm apexi header
-act xtreme pp and street disc
my question is with this high of c/r, what injectors should I run? Ive heard 310's or I have some H23 injectors should i run those? and what kind of numbers do you think it will put down? the c/r with a 1 layer is 12.5:1, or any other suggestions? I want this motor to be as budget as possible keep in mind, thanks!
Old Apr 5, 2004 | 06:50 PM
N1 Andy's Avatar
R.I.P. Andy
Default Re: what can I expect with this setup? (Slow Jdm EG6)
anyone?
Old Apr 5, 2004 | 07:00 PM
Used2beAb16's Avatar
you can get away with stock injectors and a fpr if need be.
Old Apr 5, 2004 | 07:27 PM
N1 Andy's Avatar
R.I.P. Andy
Default Re: what can I expect with this setup? (Used2beAb16)
thanks, what psi should I set the fpr to?
Angel4768
Sep 26, 2010 05:17 PM
Bay Area Baller
Dec 11, 2006 10:03 PM
SkoundrelUSA
14
Jul 19, 2006 05:34 PM
hip_hop_s0ulchild
Oct 26, 2005 05:47 AM
blakacintegera
Aug 9, 2003 10:55 PM
