What size rims?
Old Mar 29, 2004 | 06:51 PM
gofastgsr's Avatar
Default What size rims?
I want to improve my traction and handling and was wondering how wide of a 16 inch rim will work on a GSR with minimal rubbing. What size wheels and tires are you guys running?
Currently the car is lowered 1.5 inches but I might install Type R springs because I I think the car is a little low.
Old Mar 29, 2004 | 06:55 PM
Ti3d in's Avatar
Default Re: What size rims? (gofastgsr)
16X7 with 205/50/16 tires should work.
Old Mar 29, 2004 | 06:57 PM
White GSR '01's Avatar
Default Re: What size rims? (Ti3d in)
ditto
Old Mar 29, 2004 | 07:38 PM
silvrintegra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ti3d in &raquo;</TD></TR><TR><TD CLASS="quote">16X7 with 205/50/16 tires should work.</TD></TR></TABLE>
Perfect size for that size wheel.
Old Mar 29, 2004 | 10:10 PM
SonicBlueTeg's Avatar
Default Re: What size rims? (silvrintegra)
16x7.. 205/45/16's i road race/track practice with em too.. they do just fine.. i have no idea how many inches my lil Applekat is lowered.. she's got a 2 fingergap all the way around..
Old Mar 29, 2004 | 10:24 PM
garados's Avatar
I was running 215.40.16 then 205.40.16's and they were pretty cool. Lowered 2.5-3" in front and 2-2.5" in back and it handled alright. Now, I raised the car about 1.5 inches all around and it handles muuuuch better with 195/60/14 azenis
Old Mar 30, 2004 | 10:28 AM
Creep's Avatar
205/45/16
Old Mar 30, 2004 | 11:00 AM
Type Wah's Avatar
I'm running 205/40/16 on my 16x7" wheel. So far so good.
Old Mar 30, 2004 | 11:06 AM
Honda Hick's Avatar
Can you run 215 wide tires on 16s? The most contact area would be best IMO.
Old Mar 30, 2004 | 11:23 AM
rapid_roy's Avatar
Default Re: What size rims? (Honda Hick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Hick &raquo;</TD></TR><TR><TD CLASS="quote">Can you run 215 wide tires on 16s? The most contact area would be best IMO.</TD></TR></TABLE>
If you do something that takes advantage of that. It might be worth .2 seconds on an autox course if you are good enough.
A sticker smaller tire will be better than a heavier tire. Azenis for instance only come in 215/45/16 which will be heavier and change your gearing. A 205/50/15 Azenis would be a better choice.
Old Mar 30, 2004 | 11:37 AM
MassScene's Avatar
to big... 45's is the next size down. 50/16's is accord/prelude size
Old Mar 30, 2004 | 11:54 AM
ubreak_ubuy's Avatar
Default Re: What size rims? (SonicBlueTeg)
those are some clean *** OG wheels. i luv them!!
Old Mar 30, 2004 | 12:10 PM
quikB18B's Avatar
Default Re: What size rims? (raceinspired)
16x7 205/45/16 is perfect for an average dropped G3
Also keep in mind unless you car is slammed a 40 series looks silly imo on a g3, theres just to much gap and the wheels look tiny. The 45 series gives it a meaty look, while fitting nicely in your wheel well. Also you don't have to worry about bent rims every other month
50 series= way to big Cough 4x4
Old Mar 30, 2004 | 02:02 PM
gofastgsr's Avatar
From the responses and the fact that I do not want to change my gearing. The preferred size combination is 16x7 with 205/45/16. The question is will I get improved handling over my current 205/50/15?
Old Mar 30, 2004 | 04:01 PM
KaBlammyman's Avatar
go with the widest 15" rim you can find. The rim only needs to be big enough to clear your brakes. Anything bigger is just adding rotating intertia...which is not good.
Old Mar 30, 2004 | 06:15 PM
StolenTeg's Avatar
Default Re: (KaBlammyman)
Them rota slipstream that are 15x7 seem good? i've ordered them and be here on friday. Going to get some 205/45or50/15. dont know what tires i will get but got azenis on my 14 in stock rim and they are a dream .
Old Mar 30, 2004 | 06:19 PM
89hatchback's Avatar
Default Re: (StolenTeg)
I say go with the Rota Slipstreams 15X7 and some Falken Azenis 205/50r15 tires.
Old Mar 30, 2004 | 06:29 PM
Nihilation's Avatar
Default Re: (89hatchback)
If I get rid of my Work wheels, this is what I'll be running. Slipstreams, gunmetal with a polished lip....mmmmmm mmmmm, bitch!
Old Mar 30, 2004 | 07:59 PM
xSCTYGx's Avatar
Default Re: (Nihilation)
i would say 205/45/16 would be your best bet...
Old Mar 30, 2004 | 08:06 PM
mpintegra96's Avatar
16x7 and 205/45/16 should be just right
Old Mar 31, 2004 | 05:56 AM
gofastgsr's Avatar
Is the 16X7 rim big enough to install a brake upgrade kit (like the AEM)?
Old Mar 31, 2004 | 06:05 AM
ernald711's Avatar
215/45
Old Apr 4, 2004 | 02:24 PM
gofastgsr's Avatar
I am trying to justify new rims.
If I want more performance should I run 225/50/15 (wider tire) Yokohama AVS ES100 tires or
Get some 16's and run 215/45/16?
Two things, don't need rims and the tires for 16's are more expensive. I just want more perforamance??? Currently running 205/50/15 Azenis on stock rims.
Modified by gofastgsr at 11:55 PM 4/4/2004
Old Apr 4, 2004 | 03:06 PM
BolivianDc2's Avatar
Default Re: (gofastgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gofastgsr &raquo;</TD></TR><TR><TD CLASS="quote">I am trying to justify new rims.
Modified by gofastgsr at 11:55 PM 4/4/2004</TD></TR></TABLE>
if you just want improved performance, get some cheap light 15x7 rims, and use those tires on them.
Old Apr 4, 2004 | 03:17 PM
Comp97GSR's Avatar
Default Re: (BolivianDc2)
I have 98 spec R rims, 16x7 with 215/45's. 1 finger gap and no rubbing.
edit: 225's will rub if the car is lowered without spacers.......
