confused about wiring in civic, not having good luck with people repling. Please.
i have a 98 civic coupe. with that said, i have ordered a 95 gsr complete swap. when it showed up, the wiring confused me a little. my 98 ex harness for the motor goes all the way inside the the kick panel to the ecu. the gsr harness is shorter and stops at the passenger side strut tower. i really need help. i want to use this set up with an aftermarket computer, so getting the proper wiring is important to me.
Yeah i would take that gsr harness off the motor and sit it to the side. You might need a few plugs off of it. You will use your EX harness, you just need to extend a few thinks and add the iab wiring as said above. Any specific questions you can PM me. Good luck.
95 gsr's are obd1 and 98 civics are obd2 you need a conversion harness, or you can use the one off the motor and make your own
where do you get a conversion harness? how expensive are they?
i tried looking at hasport, but they dont sell a harness for my swap.
Modified by 3dcivic at 3:43 AM 4/1/2004
contact Blown90hatcH, or the is more people on h-t that make them too also.
do a search
do a search
gtowni3
Sep 26, 2004 09:55 PM
