need help with ls vtec swap
Old Mar 29, 2004 | 05:26 PM
GRLRACR's Avatar
Default need help with ls vtec swap
i have a 92 cx hatch w/ a 97 ls motor swap. i'm wanting to make it vtec. what all do i need to buy and do. i'm trying to get an exact list together of <U>everything</U> needed! thanks
Old Mar 29, 2004 | 05:28 PM
noslude93's Avatar
Default Re: need help with ls vtec swap (GRLRACR)
Do a fast search its been covered!
lsvtec ls vtec either or works ! good luck .
://www.honda-tech.com/zerothread?id=811010
Old Mar 29, 2004 | 05:30 PM
GRLRACR's Avatar
Tried that thanks. didn't find a how-to or anything.
Old Mar 29, 2004 | 05:33 PM
torr's Avatar
Default Re: (GRLRACR)
c-speed.com, theoldone.com
Old Mar 29, 2004 | 05:37 PM
GRLRACR's Avatar
c-speed.com didnt work but the other did. thanks!
Old Mar 29, 2004 | 05:45 PM
torr's Avatar
Default Re: (torr)
well, i guess i can help rather than just typing some addy's up there.
so basically here's a quick rundown.
new ls headgasket, new water pump, new timing belt, (some people use gsr's but i used a b20), arp headstuds for a gsr, 1/8th plug ( to plug up the existing vtec oil hole on the underside of the head, use a drillbit to make the hole bigger then tap it with a 1/8th tap, then use loctite and screw the plug in. get a ls/vtec oil line kit ( kit comes with ss line and fittings. golden eagle ls/vtec conversion kit works well.
there's so much more and american choppers is about to come on so, lates.
Old Mar 29, 2004 | 08:36 PM
N1 Andy's Avatar
R.I.P. Andy
Default Re: (torr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRLRACR &raquo;</TD></TR><TR><TD CLASS="quote">c-speed.com didnt work but the other did. thanks!</TD></TR></TABLE> maybe cuz its c-speedracing.com! hella good website, and you cant just expect to slap a vtec head on and smash out, if you dont switch out the ls pistons its gonna be hella low compression and pretty damn slow, put some ctr's or b16 pistons in if youre gonna go with a daily driven n/a car. good luck and check out c-speedracing.com! it has a compression ratio calculator, (my favorite part of the site) I prefer AEBS head studs over ARP too imo...
Jaymee1782
Mar 27, 2016 08:42 PM
nelsonb16
Sep 24, 2007 04:49 PM
jbj-kustomz
May 27, 2005 09:11 AM
da-6_ls
Dec 29, 2004 08:09 AM
Gimpo
Apr 12, 2004 09:48 PM
