HELP: MOMO steering wheel w/ quick release (Experienced DIY's ONLY)
Okay now here's the deal. I've looked up in the Helms Manual on how to get the steering wheel off, now i've done that and now I've encountered a couple obstacles putting on my MOMO Tuner wheel ----->
First off, I couldn't find a way to attatch the horn button (not the horn wiring) to the wheel with my quick release. There seems to be no room for the horn if i want the quick release attatched. here's a pic of my quick release ---->
Second off, my turn signal lever doesn't retrack after i signal and make a turn. Is there anyway of doing this without have'n to put back on the reel.
Third, the diagram from MOMO for the Integra Hub, it seems that you have to take apart the reel and use the back part only. This is another concept I don't understand since there are like 3 prongs on my quick release that dig into the back.
IS there a quick release hub out there that lets you attatch the horn with no problem. I wouldn't mind connecting and disconnecting the wires everytime I take off the wheel.
Lastly, does anyone know of a good way to remove the hub. It seems that it's stuck on there pretty hard (even with the 19mm off). I've searched and I've had no luck.
Should I attach the wheel permanently and not use a quick release????
Thanks for looking and thanks in advance for your everyone's help!!!
This is really wierd. I have exactly the same problem, with exactly the same wheel.
Let me guess, you're using the 4914 hub right? Yeah. I had the same issues. I'm pretty sure you need to buy the 4911 hub (the one for non-cruise control) and that one works better.
I haven't bought it yet, so don't quote me on it.
Yes, the QR hub you are using does not allow for the use of the horn button. Sorry. Buy a new one if you want to keep the horn. Or, re-wire the horn to a new location.
Sorry to be the bearer of bad news.
