B18 questions?
Old Oct 23, 2001 | 09:41 PM
Themillman's Avatar
Default B18 questions?
Where can I get info about putting a b18a/b into a crx?
Here are the questions I was wondering about
What is the diff between a b18a and a b18b
does the crx si engine wire harness plug right up to the motor?
Are all B-series flywheels the same(as in same bolt pattern)?
Does the teg ecu plug into the under-dash harness?
Thanks
Old Oct 23, 2001 | 10:53 PM
Backyard Speical's Avatar
Default Re: B18 questions? (Themillman)
i think the b18a is off the 90-93 integras and the b18b is 94 and up(i think).
the harness doesn't plug right in but you could make it work, just got to play with it. and all the b series flywheel has the same bolt pattern. and all the obd ecu plug into obd
Old Oct 24, 2001 | 06:01 PM
B18b Turbo's Avatar
New User
Default Re: B18 questions? (Prodigy 2.2 EK)
ive got a b18a1 in my crix with a b18b head.w/the 18a1 head it felt slower than when i swapped the 18b head get the b if you have a chance or get the a1 and find a b head [IMG][/IMG]
beyondstock
Mar 5, 2009 08:37 AM
m00nr0ck Si
May 12, 2007 05:35 AM
hgw84
Mar 7, 2006 06:07 PM
e jay one
18
Jan 26, 2006 01:28 PM
iwouldHITit
Feb 19, 2003 09:10 PM
