No signal flashing on screen..video inside..
Old Mar 29, 2004 | 02:48 PM
stickercuttingcom's Avatar
Default No signal flashing on screen..video inside..
I have this problem where whenever I turn on the tv in my car, it just flashes no signal over and over again while showing the video. The video shows fine but the intermmitant flashing of the no signal makes it pretty difficult to watch. Everything is attached fine in the back, I have checked it numerous times.. I have tried wiring the tv up to the cd player wires and up to the fuse box, both with the same result.
Here is the video so you can see what its doing. Has anyone else had this problem? This tv has always done it. Do I need an amp for it? I'm afriad to burn it out with to much power. Its hooked up to a dvd player under the seat.
http://www.stickercutting.com/nosignal.AVI
Right click, save as..the server doesn't stream well.
Thanks,
Nate.
Old Mar 29, 2004 | 03:04 PM
vigor5spd's Avatar
Default Re: No signal flashing on screen..video inside.. (stickercuttingcom)
I would replace the video cables and see if the problem still persist. If it does then try a different video source like a playstation. If the no signal problem still happens with the playstation then its your input on your monitor.
Old Mar 29, 2004 | 03:15 PM
I read on the website just now that I should use a 5 amp circuit fuse on the fuse box with an add-in fuse setup. Right now I am using whatever came factory in the car (96' Honda accord). Do you think that could present a problem? I think its a number 15? Can't remember off the top of my head.
Old Mar 29, 2004 | 03:22 PM
vigor5spd's Avatar
Default Re: (stickercuttingcom)
No.
It the video signal going into the monitor. Check and replace the video cables and see if problem still occurs. Then or try a different video source.
poprocksncoke
Apr 1, 2016 09:58 AM
tegman85
Audio / Security / Video
Jul 19, 2007 10:08 AM
TheMuffinMan
Dec 19, 2006 03:11 PM
civic-cpe
May 3, 2005 06:49 PM
egizzle8
Jun 23, 2004 10:20 PM
