strange ECU code question
i have personally looked at my friends CRX so this is no bullshit
the ECU throws 17 SHORT blinks with no pause in between them to differentiate the codes, the CEL comes on every once in a while after driving.......WTF is going on here?
in theory that would be correct...17 short blinks would be a code 17....but...there is normally a long blink to act as a 10...does it even just use only short blink...?does your speedo work ok?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StripShowHatch »</TD></TR><TR><TD CLASS="quote">in theory that would be correct...17 short blinks would be a code 17....but...there is normally a long blink to act as a 10...does it even just use only short blink...?does your speedo work ok?</TD></TR></TABLE>
USDM cars only have close to 20 codes... it will blink them all independently
if is a JDM ECU, it will blink a long blink=10 and then 7
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp »</TD></TR><TR><TD CLASS="quote">i knew you guys would say this, the speedo works PERFECTLY FINE, and no the 10's are signified by long blinks so there is not 17 short blinks as 1 code</TD></TR></TABLE>
17 blinks is one code. If there was one long *** blink(for some reason) it would mean your O2 sensor is coding.
all these post and no one responed correctly..
ALL!!! OBD0 ecu's blink in short blinks, every blink is a 1+1+1.. and so on
OBD1 and UP have the long blinks for 10s and shorts for 1s...
thats the correct answer!..
gees
and this is a tech forum come on people get with the program
gees
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JonGP4 »</TD></TR><TR><TD CLASS="quote">all these post and no one responed correctly..
gees
and this is a tech forum come on people get with the program</TD></TR></TABLE>
What do you mean...he said he had 17 short blinks...so that's code 17...he obviously have problems with his cluster/vss...
Your reply doesn't even answer his question....he didn't ask how to read obd0 and obd1 ecu's...
gees
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skelly ed6 »</TD></TR><TR><TD CLASS="quote">
17 blinks is one code. If there was one long *** blink(for some reason) it would mean your O2 sensor is coding.</TD></TR></TABLE>
no 1 long blink, pause and 7 short blinks=code 17, this is 17 short blinks and as stated THE CLUSTER WORKS FINE no issues with it at all ever
i have a jdm pr3 non obd ecu and when it throws codes that are higher than 10 it WILL blink one long time then give me the short blinks.....i have seen a few jdm pr3/pwo non obd ecus and they all respond this way... i dont know about usdm or obd1/2 ecus tho...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paybac4223 »</TD></TR><TR><TD CLASS="quote">i have a jdm pr3 non obd ecu and when it throws codes that are higher than 10 it WILL blink one long time then give me the short blinks.....i have seen a few jdm pr3/pwo non obd ecus and they all respond this way... i dont know about usdm or obd1/2 ecus tho...</TD></TR></TABLE>
who cares about obd-1 or obd-2 ecus? this is about an OBD-0 ecu
mybabyintegra
15
Sep 19, 2008 05:04 PM
Coltmorris
Nov 2, 2006 07:15 PM
blackeg
May 12, 2005 04:06 PM
