car is burning gas
Old Mar 29, 2004 | 11:13 AM
Steve90HB's Avatar
Default car is burning gas
I am getting 12 mpg, I changed out my fuel filter and I'm not throwing any codes... occasionally there is a gas smell, fuel pump clicks on fine. Any ideas of what could be causing it? The car is a 94 Nissan Sentra, it should be getting 30-38 mpg
Old Mar 29, 2004 | 11:25 AM
Kal's Avatar
Kal
Default Re: car is burning gas (Steve90HB)
any sort of leaking at all?
Old Mar 29, 2004 | 02:05 PM
Steve90HB's Avatar
Default Re: car is burning gas (Kal)
only when gas tank is full, it has that odor, forgot to mention that problem
and supposebly that's when there was a little leak too
Old Mar 30, 2004 | 06:40 AM
Steve90HB's Avatar
Old Mar 30, 2004 | 06:47 AM
showtymers619's Avatar
* B A N N E D *
look at are your fuel rail...
Old Mar 31, 2004 | 04:27 PM
Steve90HB's Avatar
Default Re: car is burning gas (ShowTymers619)
looks normal
I'm about to take it in for a full diagonostic, but could still use ideas
Old Mar 31, 2004 | 06:09 PM
t0eKnEe's Avatar
I had that same problem one time. It ended up being the gas cap. Changed it and it was fine after that.
Old Mar 31, 2004 | 07:37 PM
blah13's Avatar
Default Re: car is burning gas (t0eKnEe)
Check for any punctures in your tank, fill it up, turn the ignition on and off a couple times, then get under there and look around. Start at the tank and follow the line as best you can. There has to be a leak somewhere. If the car was running rich enough to burn that much fuel your car would bog like nobodys business and be smoking all day.
Edit : I see your in the 904, where you at? If you need I can take a look at it for you sometime on the weekend.
Old Apr 1, 2004 | 07:58 AM
Steve90HB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0eKnEe &raquo;</TD></TR><TR><TD CLASS="quote">I had that same problem one time. It ended up being the gas cap. Changed it and it was fine after that.</TD></TR></TABLE>
was there anything visibly wrong with the gas cap? That sounds weird that a gas cap could leak out a couple gallons of gas
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
I checked aruond the fuel tank and lines there are no visible leaks/dripping anywhere... but this wasn't done on a full tank because I can't afford a full tank right now
I live in the Orange Park / Middleburg area
Old Apr 1, 2004 | 06:53 PM
blah13's Avatar
I'd say its a leak, a friend of mine had a bad one, it woudl leak just under half his tank over a day, so hed end up with like 16mpg. I'm up at 103rd, not too far if you ned some help.
Old Apr 1, 2004 | 07:48 PM
thad
Guest
Posts: n/a
Default Re: car is burning gas (blah13)
it could be pretty much anywhere something connects in you feul system. check the drain plug, hardlines, return line, etc.
also check the injector gromets, i've had those go bad. turn the key on till the pump primes then push on the injector clips and wiggle the injector, if its bad you have anywhere from a faint smell of gas to a two foot streem spray up form the feul rail.
good luck
Old Apr 2, 2004 | 08:15 AM
Steve90HB's Avatar
Default Re: car is burning gas (thad)
ok here's the deal, I just got back from driving around a little bit... started to smell a strong gas smell, checked around the tank and saw a pretty good sized wet spot.. It was definately gas and it was a pretty good amount of it
Any ideas on how to find the hole?
Old Apr 2, 2004 | 09:44 AM
mattssi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steve90HB &raquo;</TD></TR><TR><TD CLASS="quote">
Any ideas on how to find the hole?</TD></TR></TABLE>
There is a right way, and a wrong way to do this. the wrong way would be to not take out your gas tank, the right way would be to remove it, and have it professionally sealed back up!
Old Apr 4, 2004 | 11:08 AM
Steve90HB's Avatar
Default Re: car is burning gas (mattssi)
got a half tank of gas in there! anyone know what they do to "professionally" seal it?
VTECwalka
20
Jan 28, 2013 07:06 AM
nonvteclude
Oct 15, 2006 05:08 AM
TealCivic93
Apr 8, 2006 09:31 AM
chiefvtec
Mar 28, 2003 11:40 AM
