Over flow in rservior
Old Mar 29, 2004 | 10:17 AM
imaginary17's Avatar
Default Over flow in rservior
I have a 92 manual integra. My reservior over flows once in awhile. Need help fixing the over flow.
Old Mar 29, 2004 | 10:18 AM
JDMisGOOD's Avatar
Default Re: Over flow in rservior (imaginary17)
Its supposed to overflow thats what its there for!
Old Mar 29, 2004 | 10:23 AM
Default Re: Over flow in rservior (JDMisGOOD)
you sure? its over flowing and going out of the reservior. Thats suppose to be normal?
Old Mar 29, 2004 | 10:26 AM
JDMisGOOD's Avatar
its not supposed to go out of it...only into it...your car is running tooo hot...check your cooling system!
JDMisGOOD's Avatar
water pump,thermostat,radiator,radiator hoses! make sure everything is working properly!
Old Mar 29, 2004 | 10:29 AM
should i replace my radiator?
One of my friends that is a mechanic says its the thermostat. But i don't think it is cuz my temp guage isn't going higher than normal.
Old Mar 29, 2004 | 10:30 AM
i just had my second 90k tune up so i had my waterpump replaced.
211k on odometer.
Old Mar 29, 2004 | 10:31 AM
JDMisGOOD's Avatar
start with the small stuff! thermostat could be stuck
Old Mar 29, 2004 | 10:32 AM
i'm thinking its my radiator. everything else is working fine. I had no over heats.
Old Mar 29, 2004 | 10:33 AM
JDMisGOOD's Avatar
well make sure the coolant system has been bleed properly too!
Old Mar 30, 2004 | 11:06 AM
i'm probably just gonna get a new radiator just to be in the safe side.
Old Mar 30, 2004 | 11:07 AM
JDMisGOOD's Avatar
start with the small stuff! ic ould be something simple!
Old Mar 30, 2004 | 12:39 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMisGOOD &raquo;</TD></TR><TR><TD CLASS="quote">start with the small stuff! ic ould be something simple!</TD></TR></TABLE>Like the radiator cap...
Check all 3 of the sealing surfaces of the cap & the radiator neck. The cap needs to allow coolant to flow out to the tank when the pressure exceeds 15psi or whatever. Then when the radiator cools down it needs to open another seal to suck coolant back in from the reservoir. All the while, the largest-diameter seal has to stay airtight, otherwise it'll suck in air instead of coolant.
Or maybe even simpler... A leak in that little rubber hose will also draw air back into the radiator instead of coolant.
Old Apr 1, 2004 | 07:28 AM
Default Re: Over flow in rservior (JimBlake)
thanks for the tip. I'll check out the lil rubber hose for a leak.
But just to clarify things - I over Flow only once in awhile though. Not all the time
JoshMerchant
Mar 13, 2015 10:27 PM
Axatax
Sep 13, 2013 01:38 PM
92VtecTeggy
Jun 20, 2003 08:13 AM
Specialk
May 22, 2003 08:59 AM
dbman96
Mar 11, 2002 02:43 PM
