JUN 3 cams - Dyno numbers??
Old Mar 28, 2004 | 10:46 PM
Louie_EM1
Guest
Posts: n/a
Default JUN 3 cams - Dyno numbers??
First off, hello to everyone on the ITR forums.
I will be installing a poor-man type R within the next week and basically it's a:
B18c1 block with JDM p73s
B16a2 head with JUN 3 cams
Basically does anyone have #s on JUN 3 cams on lightly modded R motors? (I am assuming that USDM and JDM pistons are not going to be a huge difference so either or would be great)
Thanks guys.
Old Mar 29, 2004 | 01:38 AM
ilovemyhonda's Avatar
Default Re: JUN 3 cams - Dyno numbers?? (Louie_EM1)
try the all motor forum
Old Mar 29, 2004 | 01:45 AM
rodimus's Avatar
Default Re: JUN 3 cams - Dyno numbers?? (ilovemyhonda)
you want to "highly" mod your car with those cams. they see alot more power from 5700-9500 rpm's.
port n polish head would be nice.
i hope you have alot of other stuff on your car, plus dyno tuning.
Old Mar 29, 2004 | 05:10 AM
Louie_EM1
Guest
Posts: n/a
Default Re: JUN 3 cams - Dyno numbers?? (EVOL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVOL &raquo;</TD></TR><TR><TD CLASS="quote">you want to "highly" mod your car with those cams. they see alot more power from 5700-9500 rpm's.
i hope you have alot of other stuff on your car, plus dyno tuning.</TD></TR></TABLE>
Yea I got some other goodies.
But I am just lookin to see if anyone has them on their R that has dyno number, and see wha tkinda set up they're running.
Reason being, my mechanic and I are having a dipute about the power being made, these cams were simply overkill on the B16a2.
Old Apr 5, 2004 | 08:07 AM
all-b18c5-motor's Avatar
check out performance and dyno charts at http://www.importreview.com. they will have some numbers for you there, and comparissons to other options
Old Apr 5, 2004 | 08:16 AM
Philly_NBP_R's Avatar
Default Re: JUN 3 cams - Dyno numbers?? (all-b18c5-motor)
Old Apr 5, 2004 | 08:18 AM
00MRSi's Avatar
Find another mechanic.
Try contacting AzSi22. I think that's his h-t name. He is running a C1 block with B16 head, as far as I can remember.
Old Apr 5, 2004 | 08:51 AM
MissMyHonda's Avatar
Default Re: JUN 3 cams - Dyno numbers?? (Philly_NBP_R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philly_NBP_R &raquo;</TD></TR><TR><TD CLASS="quote">
That seems a little low no? Is that SAE corrected?
Old Apr 5, 2004 | 11:25 AM
Louie_EM1
Guest
Posts: n/a
Default Re: JUN 3 cams - Dyno numbers?? (JoesTypeS)
That does seem low.
Well is that all the mods he's got?
Old Apr 5, 2004 | 11:58 AM
splitime's Avatar
Those numbers don't look so hot. Ive seen similar top end and more midrange (HP/TRQ) with a stock R setup. Then again, dynos do lie.
Old Apr 5, 2004 | 12:06 PM
92TypeR's Avatar
FSAE
Default Re: JUN 3 cams - Dyno numbers?? (splitime)
On a mild compression block with good supporting mods expect around 200whp after good tuning. Simply bolted in, 190whp would be my guess.
Old Apr 7, 2004 | 06:30 PM
IntegraXTR's Avatar
bump..
i'm in the same boat..
i have a gsr and planning on getting JUN cams/springs, etc..
searching HT for people's feedbacks on the cams as well =P
Racewerkz
25
Jun 18, 2010 10:24 PM
GsrSleeper18
Sep 13, 2004 10:30 AM
knalige
May 28, 2004 05:15 PM
SJTrance
May 8, 2004 07:55 AM
GIANT
Feb 6, 2003 12:28 PM
