ITR rear sway to fit a 98+ GS what parts do i need....
Old Mar 28, 2004 | 10:16 PM
defconsc's Avatar
New User
Default ITR rear sway to fit a 98+ GS what parts do i need....
I was wondering what i need to fit a ITR rear sway onto a 98+ GS teg. I'm getting the bar soon and the beaks kit as well. My question is can i use the endlinks on the GS teg with the ITR bar, or do i have to buy ITR endlinks? If i get the Beaks kit, what other parts do i need to make the the ITR sway fit. thanks
defconsc
Old Mar 28, 2004 | 10:47 PM
thaiphob's Avatar
Nikon!!!
Default Re: ITR rear sway to fit a 98+ GS what parts do i need.... (defconsc)
you can reuse the endlinks from you Ls and just make sure you get these parts :
1.) 52300-ST7-Z01 rear swaybar ($58.22) -- only if you havent got the bar yet
2.) 52315-ST7-Z01 swaybar bushing ($3.27) (2 needed)
3.) 52308-SS0-000 bushing bracket ($5.14) (2 needed)
4.) 52316-ST7-Z00 endlink bushing ($1.46) (2 needed)
5.) 52312-ST7-Z00 endlink bushing collar ($4.16) (4 needed) – this part can be reused from the stock swaybar
6.) 90175-ST7-Z00 bolt (8x35) ($2.06) (2 needed)
7.) 94050-08080 flange nut (8mm) ($0.10) (2 needed)
buy them here :
http://www.acuraparts247.com
Old Mar 28, 2004 | 11:13 PM
defconsc's Avatar
New User
Default Re: ITR rear sway to fit a 98+ GS what parts do i need.... (thaiphob)
hey thanks for the info, very useful
Old Mar 29, 2004 | 02:53 AM
WhoisDan's Avatar
Get the BSQ kit. It is cheaper and easier to install. Works the same.
SOHC_MShue
33
Sep 8, 2003 06:24 PM
roninb18
Jan 30, 2003 06:09 PM
SilverGS
Nov 14, 2001 10:25 AM
gsr94
Aug 15, 2001 03:30 AM
