b16 engine swap into 88 CRX si
Old Mar 28, 2004 | 07:19 PM
fishin9975's Avatar
Default b16 engine swap into 88 CRX si
Maybe im just a dumbass, and somebody has asked this question before, but anyways... How difficult is it to swap a b16a engine into an 88 CRX si? I mean how much money am I looking at just for the tools and ****, not for the engine, tranny etc. Plus how do i learn the in's and out's of a honda engine??? Any help would be greatly appreciated.
~Tim
Old Mar 28, 2004 | 07:28 PM
rsbad454's Avatar
Default Re: b16 engine swap into 88 CRX si (fishin9975)
https://honda-tech.com/zerosearch
Old Mar 28, 2004 | 07:38 PM
Redline130's Avatar
Expect to dish out at least $250 for miscellaneous other stuff. Before you swap a motor in, you should highly consider replacing certain parts. These include the water pump, timing belt, thermostat, hoses, clutch, sparkplugs, distributor cap and rotor, etc. At the very least, I would change the timing belt, water pump, plugs, distributor cap and rotor. You'll probably need to get new hoses anyway, as they will either be cut or not included with the motor. You will need a decent tool set, one of those 150pc Craftsman one's will be suffcient. Plus you'll need a hammer, a 32mm socket (axle nuts), a pry bar, not too mention coolant, oil, oil filter, brake cleaner, and grease. Unless you have one, you will also need a engine hoist to get the motor in the car. A jack and jack stands are a necessity too. I also highly recommend that you get a factory manual. Go here to get one: http://www.helminc.com
Old Mar 28, 2004 | 10:21 PM
Rywire's Avatar
Default Re: b16 engine swap into 88 CRX si (Redline130)
Click my website in my sig, all you need to know. Ryan
Nocturnal
Feb 23, 2009 10:41 AM
bmxbikes
Jun 18, 2007 07:03 PM
gobblebox59
45
Apr 12, 2004 06:56 PM
alleyezonme
Apr 8, 2004 08:26 PM
