Idea On Injectors.
Hey I Need Some Ideas On InJectors I Am Planing on turboin my car really soon I Need Some Good Injectors But I Dont know where to get it from and would i need a new fuel pump?
you'll need a secondary in-line fuel pump or a intank pump that will handle atleast 100 psi. and a fuel management unit or any other management unit. it all depends on your set
Depends on what kind of fuel management your going to use.
If you use hondata or any there standalone you'll need larger injectors (450cc+).
If you are using a fmu set-up the stock injectors will be fine up about 6psi above that you'll need to get larger injectors.
It all depends on your fuel managment....search to find more info
ja20_eg
Engine Management and Tuning
Sep 19, 2012 11:14 AM
deucedeuceEK
Jun 2, 2007 04:33 AM
