IS the B&M regulator good enough to use with a walbro 255lph fuel pump??!?
Old Mar 28, 2004 | 12:47 PM
Red D Dragon's Avatar
Default IS the B&M regulator good enough to use with a walbro 255lph fuel pump??!?
WEll i have a b&m regulator and gauge and i just got my 255 fuel pump in. I havent opened it or anything but my friend running a 255walbro in his turbo car with 440 injectors says he needs a higher flowing fuel regulator. So my question is. I have stock injectors and its all motor so can the b&M regulator handle the walbro 255lph fuel pump. IF anyone can help that would be awesome. I wanna know if i have to send it back to get a 190. THanks
~rob
Old Mar 28, 2004 | 01:17 PM
TimoneX's Avatar
New User
Default Re: IS the B&M regulator good enough to use with a walbro 255lph fuel pump??!? (Red D Dragon)
I don't see why not. I'm using the B&M unit with 400cc injectors and stock pump w/o a problem. There seems to be plenty of adjustment range with the stock pump, so I'd guess you'll be fine.
Old Mar 28, 2004 | 02:05 PM
Keith P's Avatar
Default Re: IS the B&M regulator good enough to use with a walbro 255lph fuel pump??!? (TimoneX)
I was wondering the same. Can the stock regulator, or even a modded (B+M, etc..) regulator handle the extra flow of a 255? I've read about using a small drill bit to enlarge the orifice of the regulator. I wonder how reliable this method is.
Old Mar 28, 2004 | 02:42 PM
anyone?
Old Mar 28, 2004 | 07:23 PM
Is anyone using a 255lph fuel pump with b&m regulator and stock injectors having any problems?
Old Mar 29, 2004 | 08:20 AM
bump..
Old Mar 29, 2004 | 08:38 AM
RTE117's Avatar
I'm doing it. I had to modify the B&M to allow more vaccum to lower the fuel pressure though cause it was too high.
Old Mar 29, 2004 | 09:23 AM
Redline130's Avatar
Default Re: (Red D Dragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red D Dragon &raquo;</TD></TR><TR><TD CLASS="quote">Is anyone using a 255lph fuel pump with b&m regulator and stock injectors having any problems?</TD></TR></TABLE>
I have a 255 Walbro and a B&M unit with stock injectors. No problems whatsoever, didn't have to mod the regulator either. A/F ratio is good too.
Old Mar 29, 2004 | 05:41 PM
Default Re: (Redline130)
Now thats what i wanted to hear. thanks.. makes me feel better. I really want to get my car tuned... thanks for the replies
Initial_drift
Feb 2, 2007 03:49 PM
si0385.
Jan 14, 2006 11:51 AM
Mr.Death
Jun 22, 2005 01:12 PM
snoochtodanooch
Dec 24, 2004 03:22 PM
