flywheel compatibility
I have a b16a1 In my 91 Integra with a demolished flywheel. Will a replacement for a del sol from autozone work ? or will I need to find a more specific application. If so , where do I find one? Any help would be greatly appreciated.
from what i understand, you have to use the same clutch with flywheel. like if your using a 90-91 teg clutch then you gotta use a 90-91 teg flywheel. so if my understanding is correct, you gotta use a del sol clutch too. but idk if a delsol hydro clutch will work in a cable trans
I got a clutch from a shop here in san diego. But I failed ask about a flywheel thinking it did not need replacement. They are closed today so I will probably call tomorow but I am not even sure what clutch they gave me. I just told them I had a B-16 with a cable tranny and they gave me an ACT stage 2. Hope It works.
if they know what they are doin they would have gave you a 90-91 integra clutch because thats the clutch you would use on a b16a1 with cable tranny, so you would get a 90-91 teg flywheel
Jonny Rocket
May 18, 2009 09:03 AM
impreziv
Jul 20, 2008 10:53 AM
Origin
Sep 11, 2005 08:00 PM
