Pulley bolt access
Is there anyway you can take that bolt off from under the hood?
I've allready taken off the side engine mount to allow it to drop down but I still am half an inch short of room inside the engine bay. Or is the only way from the hole inside the fender? I just dont want to put it on a jackstand when I'm heaving on it.
I noticed the helms says to take off the rear bolts on the center beam but it looks like its resting on the cross beam from the a/c bracket so I dont see how this would help.
Thanks.
Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam1am26 »</TD></TR><TR><TD CLASS="quote">take off the two bolts from the crossbeam on the drivers side, that will let it hang down a few more inches giving you access to the bolt...</TD></TR></TABLE>
ok I tried that but it only moved inwards maybe a few mills and down about 10 mills. I've still only got about 25 mills to play with between the pulley and the engine bay. The bolt clears the side and I can get to it from inside the fender but I can barely turn my breaker bar around when trying to access it under the hood. Are you guys using a smaller drive? I've got a 1/2" drive breaker bar which is about 25 mills width.
lmike6453
Jun 4, 2008 07:15 PM
