OEM intank fuel pump filter is dirty
is there a way to clean it up of all the dirt? its pretty dirty. previous owner of the integra probably put cheap gas in it. maybe replace the filter?
just curious...but, what made you take out the back seat, and open up the gas tank to see the fuel pump ?
See if the pump is an OE or aftermarket unit. Whichever it is, contact them and see if you could get a replacement for it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg »</TD></TR><TR><TD CLASS="quote">just curious...but, what made you take out the back seat, and open up the gas tank to see the fuel pump ?
low fuel pressure
low fuel pressure
I see. Well, sounds like you may want to replace it then. Who knows how long that filter has been dirty. I could've been clogged for a long period of time, causing the pump to work twice as hard to fight the dirt.
Just a though.
Just a though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsturbo707 »</TD></TR><TR><TD CLASS="quote">
low fuel pressure</TD></TR></TABLE>
*just curious* how did you find out it was low fuel pressure?
wow... what is up with all the questions about why he is checking out his fuel pump and how he knows hes gettin low fuel pressure? haha showin the newbie some honda-tech hospitality, eh?
are you running an inline with your setup? could be a faulty inline. faulty fuel filter. check it out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nyo91 »</TD></TR><TR><TD CLASS="quote">
*just curious* how did you find out it was low fuel pressure?</TD></TR></TABLE>
fuel pressure guage. DUHHH.
Wow, I can't believe this thread. Why does everyone care why, or how you found out about it...
It's just an inlet screen. If it's dirty, clean it or replace it. It sounds like you've already taken it out of the tank. Don't put it back in dirty. You can wash it & dry it in less time than it takes to get on the computer & argue about it...
Then check around inside the tank, look for more dirt. If there's lots of crud in the tank, then take off the tank & clean it. That's gonna be the big job.
just get a new strainer. it's like 10 bux. dropping the tank is prob one of the messiest jobs evar, if your car is 10year or older there's bound to be tons of dirt sludge grime all hidden up on the tank.
its probably not a bad idea to get a new strainer since the tank is already out. your car will show its appreciation on the first drive around the corner
good luck.
good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake »</TD></TR><TR><TD CLASS="quote">Wow, I can't believe this thread. Why does everyone care why, or how you found out about it...
you can eat the phat one
f'kin genious!
f'kin genious!
