testing my vtec
Old Mar 28, 2004 | 08:17 AM
masamine's Avatar
Default testing my vtec
I have a d16z6 and I was wondering how I check if my vtec is working right? Can anybody help me?
Old Mar 28, 2004 | 08:30 AM
katb16vo's Avatar
Default Re: testing my vtec (masamine)
do you have a tuning device (VAFC, vtec controller)? If so you can set the engagement point at a lower rpm and feel it kick in, but if you are just using a virgin p28 the sohc vtec is just to weak to feel it kick it.
Old Mar 28, 2004 | 08:39 AM
masamine's Avatar
Default Re: testing my vtec (katb16vo)
what is that version p28? what is that code mean?
Old Mar 28, 2004 | 08:41 AM
katb16vo's Avatar
its a ecu for the d16z6, vtec engagement point on that is like 5800 rpm. dont' tell me you have nothing to set the vtec off
Old Mar 28, 2004 | 08:47 AM
masamine's Avatar
damn that rpm is hella high. so it is optimum to get a vtec controller so i can adjust that down right?
Old Mar 28, 2004 | 09:13 AM
katb16vo's Avatar
you can search up post on this board about vtec engagement, they have alot of explanations of vtec and why honda made vtec. its not like nos or anything its just to keep your motor efficient i believe. but just search it up you'll find plenty of information
Old Mar 28, 2004 | 10:30 AM
ImportsCRX's Avatar
i just have mine set at 5,200 rpm with a VAFC.
Old Mar 28, 2004 | 10:48 AM
roadawg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by masamine &raquo;</TD></TR><TR><TD CLASS="quote">damn that rpm is hella high. so it is optimum to get a vtec controller so i can adjust that down right?</TD></TR></TABLE>
First of all, 5800 RPM is not the RPM activation RPM for the P28 ECU.
Yes, you can get a VTEC controller to switch the activation point, that is one feature of the VAFC.
Finding the optimal VTEC engagement point is not as easy as guess work, and changing it to what you think it should be. Every car is different and it needs to go on a dyno and have a tuner play with the engagement point.
Research, it sounds like you have a lot to learn.
Old Mar 28, 2004 | 11:38 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by masamine &raquo;</TD></TR><TR><TD CLASS="quote">I have a d16z6 and I was wondering how I check if my vtec is working right? Can anybody help me?</TD></TR></TABLE>
Listen for it at full throttle at 4800 RPM (if you are using the proper P28 D16Z6 ECU). It is difficult to hear if you have a stock intake system.
You should be able to tell the difference in power with VTEC vs. without. The car will lag and the torque curve will feel as if it is dropping off significantly at high RPM (5000-7200) if it is not engaging. The torque curve should feel linear up to about 6600 RPM if VTEC is working properly.
Old Mar 28, 2004 | 12:48 PM
Jurassic Four's Avatar
From: Where you cant steal it, Maryland, United States
Default Re: testing my vtec (Targa250R)
Wow, is this serious, my Vtec Jerks so hard, and sounds like a Jet. YOU CANT MISS IT, jusst keep leting it rev, sometimes mine kicks at 4800, sometimes at 5200...
Old Mar 28, 2004 | 12:56 PM
Targa250R's Avatar
be professional
Default Re: testing my vtec (Jurassic Four)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jurassic Four &raquo;</TD></TR><TR><TD CLASS="quote">my Vtec Jerks so hard</TD></TR></TABLE>
Your car is tunred wrong then and you are losing power prior to the engagement point.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">YOU CANT MISS IT</TD></TR></TABLE>
He has a D-series engine, not a B16A. The D-series VTEC engagement isn't nearly as pronounced as with a B16A and is easy to miss - especially if he is using a stock airbox.
Old Mar 28, 2004 | 01:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
Thats a bummer.
Old Mar 29, 2004 | 07:02 PM
masamine's Avatar
Default Re: testing my vtec (hybrid honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid honda &raquo;</TD></TR><TR><TD CLASS="quote">
i know i just started to learn about cars. do you know any sites that i can look at to learn about my cars or hondas in genral?
Old Mar 29, 2004 | 07:57 PM
roadawg's Avatar
i know i just started to learn about cars. do you knowany sites i can look at to learn about my cars or hondas in genral?</TD></TR></TABLE>
You're looking at it
Old Mar 30, 2004 | 10:19 AM
tgreaves's Avatar
i know i just started to learn about cars. do you know any sites that i can look at to learn about my cars or hondas in genral?</TD></TR></TABLE>
Go to howstuffworks.com and search for vtec.. Then also search on there for fuel injection.. Youll get the idea..
Old Mar 30, 2004 | 10:20 AM
tgreaves's Avatar
Default Re: testing my vtec (tgreaves)
Here..
http://auto.howstuffworks.com/question229.htm
And here
http://auto.howstuffworks.com/fuel-injection.htm
K20Z3CivicSiVTEC
Honda Civic (2001 - 2005)
May 19, 2008 08:34 PM
JDM B16A
28
Apr 1, 2006 12:27 PM
microsoft_sux
Aug 24, 2004 07:37 PM
RemerLex11
Jul 10, 2004 06:31 PM
DissidentCivic
30
Jan 14, 2004 03:59 PM
