put camber kit on...now cars all over the place
last night i finally put my camber kit on , took it for a drive and the steering is really loose, I understand that i must take it in for alignment witch is where im going later but, The steering feels really loose as if it not touching the ground..
Please dont tell me it my steering rack.. i changed it 2 yrs ago
help
help
you need an alignment.
this is like "my scrambled eggs taste like **** this morning. I know i need to cook them first, but i will do that later. Why do my eggs taste like **** this morning?"
get an alignment, most likely it will solve your woes.
(edited for spelling)
You need to tighten the adjustable bolts on them. Enough so that it won't come loose until you get it align. Your car will most likely not drive straight and even because the kit is not align correctly while you're tighten it down. When you get to the alignment shop, they will loosen it and correct it for you.
When I put my Ingalls on, I didn't really tighten the bolts and the car steer left while I'm turning the wheel right
. This is while I'm driving to the alignment shop.
LOL, glad too see it wasnt just me, My drop is 3" so the camber kit is fullty out 3degress and i tighted them while they were on the car.
This morning I noticed it wasnt as bad
The car now will stall more steady driving straight,
I guess the bushings needed to settle to its new stance.. and yah the alignment place was too busy so um 9am tommorow will do Fa Sho
The car now will stall more steady driving straight,I guess the bushings needed to settle to its new stance.. and yah the alignment place was too busy so um 9am tommorow will do Fa Sho
I spoke to a knowledegable technician and he said that there were some different possiblitys relating to camber kits and steering..Check the following
1.Inner and outter tie rods
2.Rack and pinion
3.Struts
4. if the camber kit was in fact installed correctly
5. controll arms
These are the few things that would actually affect the steering
Sorry for the long list but these are just the possiblilities that you should check out
hope you can get this solved
2.Rack and pinion
3.Struts
5. controll arms
whitexpinoy
Honda Civic (2001 - 2005)
20
Jul 9, 2008 07:55 PM
