Need HID help, PLEASE!
Alright I am using the Bosche HID ballasts using Phillips 4100K bulbs. For some reason one of lights aren't working. I plugged the bulb in to the other ballasts that was working and worked fine. Is there something wrong with the ballast, It was working fine then started to blink and then it just shut off. Is there a way I can fix it? Should I open up the ballast?
From: Why so you can pretend like youre interested, FL/OK
Probably best to pose your question directly within this thread. First off I would check the fuses, then the wiring, then the ballast. If the bulb works on the right hand side I would assume it be the wiring or the balllast. I had the same thing happen, but it was due to lose wiring on my part. Hopefully, you can be just as fortunate.
Here:
https://honda-tech.com/zerothread?id=683685
Here:
I had the same thing happen to me awhile ago, turned out my ballast was not working anymore due rain water somehow getting into it, try switching ballast and see if it works on the other side, if not its the ballast, if it does work then its the wiring on the bad side
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shaun »</TD></TR><TR><TD CLASS="quote">I had the same thing happen to me awhile ago, turned out my ballast was not working anymore due rain water somehow getting into it, try switching ballast and see if it works on the other side, if not its the ballast, if it does work then its the wiring on the bad side</TD></TR></TABLE>
dead set way to tell right there.
