lowering springs for b16
Old Mar 27, 2004 | 10:08 PM
coot_er's Avatar
Default lowering springs for b16
i just bought my first rex and im about to do a b16 swap. the car right now has some shitty aftermarket springs that bounce a lot. i plan on using this mostly for a daily driver and need to do it somewhat cheap. any suggestions on what lowering spring i can use on stock struts? im thinkin tein s-tech?
Old Mar 28, 2004 | 02:03 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: lowering springs for b16 (coot_er)
A good set of lowering springs for a B16 civic or a CRX are the Progress Auto hybrid springs, set at around 360lbs (they are progressive) they are a good compromise for handling and comfort for a heavier engine.
http://www.progressauto.com/
check with http://www.camp1320.com here for a set
stan
Old Mar 28, 2004 | 09:39 AM
coot_er's Avatar
Default Re: lowering springs for b16 (Stan D)
thanks stan!
anybody else?
Old Mar 28, 2004 | 09:59 AM
EG8R's Avatar
Get springs made for a car that has a B seires from Honda....
Old Mar 28, 2004 | 04:05 PM
rioninja's Avatar
Im running my stock SI springs in the front, which sit about 1.5" lower with the
weight from my motor and turbo. In the back im running a pair of springs from
an HF CRX, which also sit about an 1-1.5" lower than stock.
You really dont want to go too low on a daily driver, since a b-series will sit a lot
lower than the stock engine. Ive run just about every suspension setup over the
years, but after ruining a few trannies and headers/downpipes over the years,
i settled on the setup listed above.
If your really set on slamming your car, i would suggest a set of Sprint springs.
I've always loved the way they ride.
admess188
Nov 25, 2008 01:22 PM
Mr.ITB
10
Mar 10, 2007 12:58 PM
bee16a
May 4, 2006 06:12 AM
Thanks knightsport!
Dec 1, 2005 04:46 PM
johnzm
Nov 28, 2002 09:56 PM
