GSR Flywheel/Clutch set-up
Old Mar 27, 2004 | 08:26 PM
92SiBlu's Avatar
Default GSR Flywheel/Clutch set-up
I have a GSR in a 92 HB and I am trying to find a good flywheel/clutch set-up for naturally aspirated i have experimented with act but happened to get the prolite flywheel and seems to be too lite not holding up to the inertia of higher RPM's? any suggestions?
Old Mar 27, 2004 | 08:52 PM
Sliced Beard's Avatar
Default Re: GSR Flywheel/Clutch set-up (92SiBlu)
honestly i would reccomend getting the Exedy Pro Lite flywheel with a decent clutch. I have an Exedy and I LOVE it, it is light and makes reve matching oh so easy. Also since it is not aluminum you dont have to worry about it exploding.
https://honda-tech.com/zerothread?id=804908
here is a way to get one for really cheap
Old Mar 27, 2004 | 09:30 PM
chad's Avatar
Moderator
call me at the shop on monday....
8437604804
i can offer you my advise and give you special pricing on clutch flywheel combo....
Old Mar 28, 2004 | 03:46 AM
TimoneX's Avatar
New User
Default Re: GSR Flywheel/Clutch set-up (chad)
Odd, I've never heard of an aluminum flywheel exploding. I'd expect aluminum to warp under heat stress. I believe chromoly is actually the explosion candidate. Though I seriously doubt you'd see either explode.
nutz4vette
10
May 30, 2018 07:24 AM
d_mina
Aug 25, 2004 06:28 PM
B18Cej1
Aug 4, 2004 11:55 PM
Unjockable
Nov 17, 2003 04:49 PM
