OBD0-OBD2 ??????? ANY INFO
Old Mar 27, 2004 | 06:51 PM
Shiftpointshaun's Avatar
Default OBD0-OBD2 ??????? ANY INFO
an i use a 0bd0 harness with 96 obd2 intake manifold will it work
Old Mar 27, 2004 | 07:01 PM
Default Re: OBD0-OBD2 ??????? ANY INFO (Shiftpointshaun)
plz does anyone have any info
Old Mar 27, 2004 | 07:37 PM
groundedcivic91's Avatar
Sure will, I got a 97 y8 motor in my 89 Si Hatch running the OBD2 manifold. HOWEVER....you HAVE to extend the intake air temp sensor to your intake pipe and then just extend the wires. No biggie.
And there is I THINK 1 extra vacum line to hook up. Just keep your existing MAP sensor(located on firewall with a little black film canister thingy and one harness plug, and 3 vacum line) wired and hooked up as is, and run the vacuum line off of it to the vacuum hole just below runner 4 on the manifold.
Now that I confused the hell out of you, go give it a try. PS...hope your not expecting and HP gains, cause your not gonna notice
singlecamsaint
11
Oct 7, 2010 02:47 AM
stevenDAtegra
May 28, 2009 03:10 PM
NguyenDC2
Dec 12, 2007 01:51 PM
speedooo
Dec 8, 2007 08:51 AM
