hydrolocked interga
Old Mar 27, 2004 | 05:47 PM
Wpg-prelude's Avatar
Default hydrolocked interga
hey guys i was drivin home when i was idling threw a puddle, and then it happend the car starting it again,, i justalled.. i didnt try st pushed it to a parkin spot and am lettin it sit over night. u guys think the car is fucked?? would warrenty cover this? HELP ME PLEASE... and yes i know i am ****** retard dumb **** from driving through a puddle.. and by the way the puddle was up to the doors and it looked alot more shallow at the time..
Old Mar 27, 2004 | 05:50 PM
Default Re: hydrolocked interga (Wpg-prelude)
k sorry for the horrilbe spelling.. this is what happend i was idleing throgh a puddle and the car stalled.. didnt try starting it again, lettin it sit and hope for best.. what u think my chances are of my car notin be f^cked? and would warrenty cover this if they sold me the car with the cai?
Old Mar 27, 2004 | 05:57 PM
DOHChi's Avatar
no warranty will not cover ur car...when this happened to my friend, all we did was just ook put the spark plugs and cranked it for like 1 second, it threw the water out, and his car started. Right after, just change your oil too. I dunno if this helps, but it has worked numerous times for a couple of my frineds.
Old Mar 27, 2004 | 06:10 PM
should i try startin it 2night??>? or should i let it sit till 2mmorow?? the reason i am under wpg prelude name is because i am at freinds house... PLEASE HELP ME HONDA TECH
Old Mar 27, 2004 | 06:13 PM
DOHChi's Avatar
just try it tonight, just remember dont crank ur car too long or too much. i know that this is the most amateur way, but this way has helped many times. also dont forget to change ur oil.
Old Mar 27, 2004 | 06:22 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: hydrolocked interga (DOHChi)
Remove the spark plugs and crank the engine a couple quick times to get any standing water out if there is any. Use a flash light to take a peek inside the cylinders. If it looks dry get some new plugs and replace them and try to start it.
Check the oil dipstick to see if there is anything funky in there.
You did the right thing by not re-starting it and pulling over. My wife didn't and blew 3 holes in my block.
After you get it home change your oil just in case. IF you have AAA it may be a good idea to tow it home before doing anything, just in case. Good luck!
Old Mar 27, 2004 | 08:18 PM
97Alex's Avatar
CHANGE THE OIL
Old Mar 28, 2004 | 02:52 PM
97pearlwhitegsr_canada's Avatar
hears the deal,. i am the 1 who originaly hyrdo locked the teg, i took out the spark plugs cranked it 3 times.. water came out of cylinders, but i took the wires off the distributor.. i cleaned up plugs put em back in, but car wont start.. help
Old Mar 28, 2004 | 07:27 PM
Bay_707's Avatar
Default Re: hydrolocked interga (97pearlwhitegsr_canada)
new plugs maybe?
Old Mar 28, 2004 | 08:20 PM
PlastikOwl
Guest
Posts: n/a
Default Re: hydrolocked interga (707_Eclipse)
Just for future reference... water up to doors=small river
puddle=little pool of water you drive over not through.
Old Mar 28, 2004 | 08:24 PM
B18 CYA's Avatar
Damn... funny thing is im in wpg too and I hydrolocked my GS-R last month ... put a hole through the block...o well...type r swap coming within the next week or 2 ... btw do you know some kid named josh with a silver prelude? he told me his buddy got a pearl white gs-r...was wonderin if it was u?
Old Mar 28, 2004 | 08:28 PM
greenteg2k00's Avatar
Default Re: (c2nap)
just get a short ram next time you dont have to worry about hydrolocked, used to have cai on gsr but changed it to short ram dont wanna take the risk
Old Mar 28, 2004 | 09:06 PM
Savv's Avatar
Default Re: (greenteg2k00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greenteg2k00 &raquo;</TD></TR><TR><TD CLASS="quote">just get a short ram next time you dont have to worry about hydrolocked, used to have cai on gsr but changed it to short ram dont wanna take the risk</TD></TR></TABLE>
I can't agree more, after practically putting a hole in my CAI Air Filter I just went short ram,
sorry to hear about your current problem though
Old Mar 28, 2004 | 09:17 PM
slowww b18b1's Avatar
Default Re: (Wild0ne21)
the gains of short ram and CAI re minimal too so u shouldnt worry bout losing much power.
Old Mar 28, 2004 | 09:38 PM
VTECorona's Avatar
Default Re: (***** witHa DC4)
I was idling when I sucked up water and my car died. I had it towed home and did the following:
1. Drain oil
2. Remove fuel injection main relay which is near your fuses
3. Remove spark plugs
4. Detach intake and drain any water that may be in throttle body and/or intake
5. Crank motor and let all of the water shoot out. (do this bystarting the car like you normally would.)
6. Let it sit out for an hour or so and dry
7. Put in new spark plugs and oil
8. Put fuel injection relay back in
9. Start car and let idle for 20 minutes
It took a few tries for mine to kick over but it eventually did.
Old Mar 28, 2004 | 11:19 PM
riceball777's Avatar
this is why i have never and will never run a cai
Old Mar 28, 2004 | 11:24 PM
2001TypeR's Avatar
Default Re: (c2nap)
Hey, i know the guy with the silver lude, josh and i know this guy with the hydrolocked teg lol
Old Mar 29, 2004 | 07:52 AM
PlastikOwl
Guest
Posts: n/a
Default Re: (2001TypeR)
Comptech icebox
Old Mar 29, 2004 | 07:55 AM
B18 CYA's Avatar
and 2001TypeR...i know u ...lol im still in gr11 at garden city collegiate
Old Mar 29, 2004 | 08:13 AM
Default Re: (c2nap)
how much hp does the comptech ice box is it the best intake in the market, how does it compare to short rame aem
Old Mar 29, 2004 | 09:21 AM
PlastikOwl
Guest
Posts: n/a
do a search...there are plenty of topics...there was even a site that did a full dyno on several intakes, and the comptech came up on top throughout midrange by a considerable amount, whereas other intakes came above in really low end and top end....but only by a little bit.
Old Mar 29, 2004 | 10:17 AM
JDMturboLS's Avatar
man wpg-prelude that sux
the same thing happend to my freind in aug. and its sounds just like it
but anyways he went and had basic coverage and they covered it b/c its like a natural disaster or what not
his was declared totalled tho and he got the money from insurance and bought the car back then he wrecked it like a month ago and now it has a salvaged title
probley not to much help tho but still thought u might wanna know some ish&lt;98stocklude&gt; is his name
hope it works out man
Old Mar 29, 2004 | 10:28 AM
zilverz's Avatar
If it is a newer car still under warrenty ... if you put the stock intake system back on it .... and the car just happened to stall out one day and you dont know why ... wouldnt warrent cover that scenario if there was a bent rod ?
I think they would have to PROVE you did something in order for them not to warrenty it. Not just say you did such and such.
SovXietday
Dec 3, 2007 09:20 AM
DC2Header
Jan 19, 2006 12:11 AM
LsHoney84
Jan 7, 2006 08:28 AM
POWERINTEGRA
Jun 8, 2004 09:45 PM
armrslr
Feb 10, 2004 07:30 AM
