Are 90-91 teg & 88-91 crx dizzys exactly the same as 1st gen b16's?
just what the title says, I probably need a whole new distributor for my b16 and just wanted to clarify 100%.
No, but a 90-91 Integra dizzy can be made to work if you cut one of the legs off.
This has been covered many times before, try a search.
If you pick up a bad B16a distributor, you can actually swap the internals from
either the LS or stock Si distributor. The internals are identicle. Just be careful,
since they are held together with dimpled torx bits, which have a habbit of
breaking the heads off when you try to remove them. Besides that, its really
easy once you get them dissasembled.
pulse_crx
13
Jan 10, 2004 05:00 PM
