My new motor with 30 miles on it has 195(psi?) compression accross the board! Is this norma?
Old Mar 27, 2004 | 11:52 AM
CivicSoul's Avatar
Default My new motor with 30 miles on it has 195(psi?) compression accross the board! Is this normal?
I just got my motor back together and running yesterday. Today I checked the compression and it was 195 on all 4 cylinders. I read that you are suppose to gain compression with miles, as the rings seat. Is it normal for the compression to be almost up to par with 30 miles on it? My internals are CP 9:1 pistons and eagle rods with the Z6 head on the y7 block. Any thoughts or ideas? Are the rings seated?
Old Mar 27, 2004 | 12:24 PM
Drew Peacock's Avatar
Default Re: My new motor with 30 miles on it has 195(psi?) compression accross the board! Is this normal? (
Yeahs sounds real good, why do think you have problem readings sound perhaps a little to high. You disconnect the the fuel pump? Sounds like they are to me, still best to keep running it in.
Old Mar 27, 2004 | 12:34 PM
showtymers619's Avatar
* B A N N E D *
well you have low comp pistons in there...your not using full sythetic are you for the break in? .. did you get on it when you had a chance? .. what i would do is .. do a little more breaking in..slowly get your revs up with out shifting hard...but 195 is very good actually...try to use regular oil.. and when you test compression remove the ECU fuse... with the spark plugs out and the throttle wide open
Old Mar 28, 2004 | 08:34 AM
CivicSoul's Avatar
Spark plug was out, I am using nd 30 wieght,the fuel was shut off by removing the fuse and the throttle was held down. The car does not smoke at all! I have only driven it to 4000 rpm with maybe 1/2 throttle, so no, I have not "gotten" on it yet. I am not worried in a bad way, just cautious. I do not want to do another motor swap! This the third one in 6 months in my driveway! I figured out the gremlin that kept bustin ringlands in 4th gear but I am just not used to the sounds forged internals make.
Old Mar 28, 2004 | 08:39 AM
* B A N N E D *
yup alot of knocking with forged internals...
Old Mar 28, 2004 | 10:00 AM
ITSTOCK's Avatar
What do you mean by alot of knocking with forged internals? Just curious so i dont freak out when i drop my new motor in soon.
Old Mar 28, 2004 | 10:30 AM
CivicSoul's Avatar
The motor sounds like a diesel truck!
Old Mar 28, 2004 | 11:13 AM
* B A N N E D *
you will just hear noise... like lose vlaves or something LOL closest i can think of what it sounds like
Old Mar 28, 2004 | 12:19 PM
5thgencivic's Avatar
Seems a little high.. My z6 with 9:1 only had around 160psi all cylinders with around 100 miles on it. And an average of 173psi now with over 3,000 miles on it.
Old Mar 28, 2004 | 02:01 PM
ek9turbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgencivic &raquo;</TD></TR><TR><TD CLASS="quote">Seems a little high.. My z6 with 9:1 only had around 160psi all cylinders with around 100 miles on it. And an average of 173psi now with over 3,000 miles on it.</TD></TR></TABLE>
same here , 9:1 cr 175 across the board
Old Mar 28, 2004 | 02:06 PM
ladysman's Avatar
My stock block Z6 was at 210 on 2 different gauges. Both were Snap-on if that makes a difference. Some may read higher than others.
Old Mar 28, 2004 | 04:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman &raquo;</TD></TR><TR><TD CLASS="quote">
My stock block Z6 was at 210 on 2 different gauges. Both were Snap-on if that makes a difference. Some may read higher than others.</TD></TR></TABLE>
Yea, but how many miles did you have on your motor? He has 30. I think my old stock block z6 was around 165 across with 110,000 on it It will definitely vary like you said, just seemed high to me.
Old Mar 28, 2004 | 06:16 PM
gritsak's Avatar
i wouldnt worry so much as to what the compression is (within reason) but if all the cylinders are within close psi to eachother, which yours are. i dont think you have anything to worry about
Old Mar 28, 2004 | 09:37 PM
Bailhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITSTOCK &raquo;</TD></TR><TR><TD CLASS="quote">What do you mean by alot of knocking with forged internals? Just curious so i dont freak out when i drop my new motor in soon.</TD></TR></TABLE>
you got high silicon pistons man, they should be a bit quieter than normal forged ones since the piston to wall tolerance is closer to stock because they expand less. it sacrifices strength just slightly for the more 'streetable' design.
Old Mar 29, 2004 | 07:02 AM
CivicSoul's Avatar
Your just jealous!
Old Mar 29, 2004 | 07:20 AM
PM-Performance's Avatar
those compression numbers are right where they should be IMO . .
Old Mar 29, 2004 | 08:38 AM
ladysman's Avatar
Yea, but how many miles did you have on your motor? He has 30. I think my old stock block z6 was around 165 across with 110,000 on it It will definitely vary like you said, just seemed high to me.</TD></TR></TABLE>
113K
SpoolnByYou
13
Jan 4, 2007 12:14 PM
turbo77nyc
Oct 4, 2006 07:10 PM
b16ahatchcrap
Mar 21, 2006 05:00 PM
pip9
Jul 18, 2004 05:57 PM
