how do you remove shock from the rear 2000 integra
Old Mar 27, 2004 | 11:07 AM
greenteg2k00's Avatar
Default how do you remove shock from the rear 2000 integra
what bolts to remove we are having hard time please help guys we took off the bolt, brake lines are in the way please help,we are trying to install koni yellows
Old Mar 27, 2004 | 01:26 PM
svtec's Avatar
L D E S
Default Re: how do you remove shock from the rear 2000 integra (greenteg2k00)
take the break lines off the support brakets and usually i find if one person stands down on the rotor and shakes the hell out of it that bolt will come out a little easier.
Old Mar 27, 2004 | 02:19 PM
Timmy!'s Avatar
Sign up for Team-integra.net they have a how to on this with pictures.
Old Mar 27, 2004 | 03:14 PM
AnNiMosSiTY's Avatar
Default Re: how do you remove shock from the rear 2000 integra (svtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by svtec &raquo;</TD></TR><TR><TD CLASS="quote">take the break lines off the support brakets and usually i find if one person stands down on the rotor and shakes the hell out of it that bolt will come out a little easier.</TD></TR></TABLE>
What he said
Old Mar 27, 2004 | 04:23 PM
Default Re: how do you remove shock from the rear 2000 integra (AnNiMosSiTY)
thanks guys i finally got the koni yellows installed on the rear, a lot of work, great handling
smittie80
Jun 2, 2017 10:11 AM
QKRTHNU
Suspension & Brakes
12
Aug 11, 2012 05:20 AM
shabam
Suspension & Brakes
May 2, 2009 05:41 PM
91EF919
Oct 1, 2008 08:07 PM
redrelease
Sep 14, 2006 01:12 PM
