changin springs I NEED HELP!!!
Old Mar 27, 2004 | 10:08 AM
bk11383's Avatar
Default changin springs I NEED HELP!!!
im changing out the springs on the rear right now and im stuck. the little bolt on top of the srtus is froze there. and im startin to strip the indside of the "nut" with teh allen wrench im using. what do i do? any answer will help alot, thanks
Old Mar 27, 2004 | 02:50 PM
SecretAznMan4u's Avatar
impact wrench. if you dont have one, just take that strut to midas or another shop and askem them to take it off
Old Mar 27, 2004 | 02:54 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: changin springs I NEED HELP!!! (bk11383)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bk11383 &raquo;</TD></TR><TR><TD CLASS="quote">im changing out the springs on the rear right now and im stuck. the little bolt on top of the srtus is froze there. and im startin to strip the indside of the "nut" with teh allen wrench im using. what do i do? any answer will help alot, thanks</TD></TR></TABLE>
Try hammering the next larger size allen key in there. Lay the strut/spring assembly on the ground, step on it with your foot to hold it down so that the allen key pushes against the ground and won't turn, then try to turn the nut w/ the wrench. Sometimes it helps to have someone else stand on the spring while you step on the wrench w/ your foot.
RallyRedGT-V6
May 9, 2004 11:23 AM
Ziatic
Apr 4, 2004 02:17 PM
ProEater
Dec 27, 2002 02:30 PM
89 CRX SI
17
Jul 15, 2002 10:21 AM
sCeRaXn
Jun 3, 2002 11:22 AM
