fuel pump
Old Mar 27, 2004 | 04:06 AM
EK9Blitz's Avatar
Default fuel pump
would a bad fuel pump cause the car not to start?
I have a B18C-5 inside of a 96 civic hatchback. My car was running fine until it overheated one time. I fixed it and now the car wont start. I'm pretty sure I am getting spark but maybe not enough fuel. The car cranks but doesn't want to turn over. Could it be the fuel pump? any opinions would help thx.
Old Mar 27, 2004 | 08:49 AM
sohc00's Avatar
Default Re: fuel pump (EK9Blitz)
yes, if the fuel pump don't work it would't supplied the fuel to the engine and the car won't start. the fuel pump must supply enough fuel to the engine at the proper preesure in order for engine to perform properly. i would performing a visual inspection frist (ex, fuel lines, fittings and conections for leak ) make sure the fuel-tank venting system is working properly. then performing a pressure test. good luck
4doorcivic9
Jun 11, 2008 06:31 AM
iNDyCRX
Apr 24, 2008 12:54 PM
punkkid12o3
Honda Civic (2001 - 2005)
Feb 5, 2008 08:36 PM
nicko360
15
Jan 17, 2007 06:22 PM
Cameron60
Jan 16, 2007 06:04 PM
