Radiator Over Flow Question
Old Mar 26, 2004 | 10:41 PM
96 Ls lnTeG's Avatar
Default Radiator Over Flow Question
I am thinking about relocating my Overflow does it have to be level with the radiator???
Old Mar 26, 2004 | 10:47 PM
PNG's Avatar
PNG
Default Re: Radiator Over Flow Question (96 Ls lnTeG)
If it's above the radiator, it will try to siphon down to the level of the filler neck every time you take the radiator cap off. If it's below, it shouldn't be a problem, although it might not purge as well, since it will have to lift coolant a greater distance.
Old Mar 26, 2004 | 10:48 PM
dannylDAsport's Avatar
the coolent recovery tank? i dont think so, just make sure the tube is near the bottom. because when the coolent pressure gets high it sends coolent to there, and when its low its sucks from there.
Old Mar 27, 2004 | 10:22 PM
Default Re: Radiator Over Flow Question (dannylDAsport)
Anyone Else?
Old Mar 27, 2004 | 11:23 PM
hadehatch's Avatar
it actually sucks coolent back from that overflow tank?
Old Mar 29, 2004 | 07:51 AM
PNG's Avatar
PNG
Default Re: Radiator Over Flow Question (hadehatch)
Yup. It's actually referred to as a "purge tank" in some cases, because it's there to help get all the air out of the system. When the coolant is hot, it expands and forces trapped air out into the purge tank, and when it cools down, it contracts and draws fluid back into the system. It's more than a simple overflow catch tank.
Old Mar 30, 2004 | 09:10 PM
No more answers??
Old Mar 30, 2004 | 09:25 PM
2fknlo's Avatar
I have relocated mine next to the battery, which is higher than the
stock loaction. I had to since my K&N was a long type. Sucks harder too.
No problems after 3 years.
Old Mar 30, 2004 | 09:27 PM
Default Re: Radiator Over Flow Question (2fknlo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fknlo &raquo;</TD></TR><TR><TD CLASS="quote">I have relocated mine next to the battery, which is higher than the
No problems after 3 years. </TD></TR></TABLE>
Wanna move it lower next to my winshield wiper bottle
TomCurllyFry
Oct 16, 2013 02:46 AM
ZekeComa
Sep 26, 2012 10:37 AM
Buttcrack
Apr 27, 2006 07:28 PM
TeamCracka
Feb 18, 2004 11:00 PM
BoostedD15B7
Jul 3, 2002 05:26 PM
