Bremo calipers off EVO.
im asking this because i just purchased one for a great price. If i can make it fit my car for under $500, it will be well worth it. That will still be cheaper than spending money on the spoons or endless calipers. ill post pics up this week.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch »</TD></TR><TR><TD CLASS="quote">well you would have to kind a rotor that was around the same thickness and diameter and then you would have to rig up a mounting bracket</TD></TR></TABLE>
step one find out the diameter and thickness fo the evo rotor
step two find a rotor with those deimisions that will fit your civic
step three, mount the rotor to the hub with the caliper onto the rotor and make a jig out of paper then have some one fab you up a mounting bracket
step three, mount the rotor to the hub with the caliper onto the rotor and make a jig out of paper then have some one fab you up a mounting bracket</TD></TR></TABLE>
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Atheist »</TD></TR><TR><TD CLASS="quote">You can actually just bore out the 4 lug setup into the rotor, if you want to. Works for me on my baer track system</TD></TR></TABLE>
i suspect that you mean redrill the center plate to 4x100, this does work, but being that its a 5 lug rotor you will be pushing your luck
dayaftertomorrow
Acura TL, RL & ZDX
11
May 29, 2005 10:15 PM
JustLooking
Jul 9, 2003 09:01 AM
