Q: Compression Test on V-Tec according to Haynes Manual?
Old Mar 26, 2004 | 07:15 PM
diyer's Avatar
* B A N N E D *
Default Q: Compression Test on V-Tec according to Haynes Manual?
94, Accord
4 cyl., V-Tec
160,000
I recently got an Accord and wanted to do a compression test on the engine. I picked up a Haynes Manual until I could get better information. Haynes says I need to remove the center coil wire and ground it. The problem is that when I looked at the distributor cap there was no center coil wire.
A local auto repair shop told me to look under the distributor to locate the coil wire. However, a Honda service rep told me there is no coil on the 1994 V-Tec, and told me to remove the cable going under the distributor. So, the question is, regardless whether there is a coil or not, do I still need to ground this "under-the-distributor-cable/coil?"
Haynes says the reason this is done on modern vehicles is to prevent damage to the computer system/ign system ... or something similar to that.
Anyone know what I need to do?
thanks,
diyer
Old Mar 26, 2004 | 10:03 PM
Chiovnidca's Avatar
Default Re: Q: Compression Test on V-Tec according to Haynes Manual? (diyer)
Pull the ECU fuse. That will disable the ignition and fuel systems. Haynes manuals suck.
4 door beast
Mar 16, 2012 03:55 PM
S2KILLA
Dec 2, 2006 03:04 PM
jjdickm
Mar 16, 2006 03:47 PM
pootie.teng
May 27, 2005 08:56 PM
spettinger
Dec 4, 2002 11:19 PM
