nos instead of turbo
Old Mar 26, 2004 | 05:55 PM
eric416's Avatar
Default nos instead of turbo
i was gonna do a turbo set up but am having second thoughts so i wanna know wat u think i should do. instead of building the bottom end this summer i was thinking about getting a 100 shot of nos and doing some other stuff like hondata, ignition system, fuel system, pulleys, jdm tranny w/lsd etc. Right now i have done,i/h/e crank pulley, 330 injectors, chiped ecu, intake manifold and throttle body. Would my stock internals handle the 100 shot untill i build the engine next yr. what do u recommend??
Old Mar 26, 2004 | 06:08 PM
MrBui's Avatar
Default Re: nos instead of turbo (eric416)
my stock h22 held up to a 100shot easily...no need for hondata i dynoed at 280hp on a fairly stock block
Old Mar 26, 2004 | 06:11 PM
Kal's Avatar
Kal
Default Re: nos instead of turbo (n20need4vtec)
it will hold, but not for a long amount of time.
Old Mar 26, 2004 | 06:12 PM
Toretto's Avatar
The H22 will handle a 100 shot from a NOS kit no problem, but remember, if its an NX kit, they rate their shots at the wheels. So a 100 shot from an NX kit would be about a 125-135 shot from a NOS kit.
Old Mar 26, 2004 | 06:21 PM
eric416's Avatar
Default Re: nos instead of turbo (Toretto)
well im gonna do hondata to prepare for the turbo setup. will the 110 shot last for the summer, weekend use only?
Old Mar 26, 2004 | 06:24 PM
eric416's Avatar
Default Re: nos instead of turbo (jz)
no not with the price per fill
Old Mar 26, 2004 | 06:26 PM
Kal's Avatar
Kal
lol, adding any sort of extra power will cause you to crave it more.
Old Mar 26, 2004 | 06:42 PM
MrBui's Avatar
i dunno....my 100 direct port nos was a true 100 +hp did a n/a dyno and nitrous run and it was 100 more....
Old Mar 26, 2004 | 07:18 PM
supaZZZleepa's Avatar
nos = no other solution
Old Mar 28, 2004 | 07:56 AM
MrBui's Avatar
Default Re: nos instead of turbo (supaZZZleepa)
best bang for the buck but the refills adds up
Old Mar 28, 2004 | 08:12 AM
Kal's Avatar
Kal
sure does add up
Old Mar 28, 2004 | 10:08 AM
98 blacksh's Avatar
Default Re: nos instead of turbo (Kal)
anything wrong with going with zex? i have been thinking about it a lot lately , like a 65 shot or something
Old Mar 28, 2004 | 10:44 AM
SKDRCR's Avatar
Default Re: nos instead of turbo (98 blacksh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98 blacksh &raquo;</TD></TR><TR><TD CLASS="quote">anything wrong with going with zex? i have been thinking about it a lot lately , like a 65 shot or something</TD></TR></TABLE>
no, nothing wrong with it.
i believe they make wet shots now too
Old Mar 30, 2004 | 05:48 AM
MrBui's Avatar
Default Re: nos instead of turbo (SKDRCR)
cant go wrong with a direct port setup anythign else is
Old Mar 30, 2004 | 06:27 AM
SpoonREVS's Avatar
i Have A zex kit for sale $275 if your local you can pick up the bottle full if not I would have to empty it out. Its a dry kit you only need a feeding ling from bottle to computer and switch from radio shack thats about 3 bucks and you all done
cyhm
Engine Management and Tuning
Jan 10, 2015 12:51 PM
mightyjoecivic
43
May 3, 2007 10:38 AM
TheHater
Jun 27, 2002 01:24 PM
vspec12
Nov 15, 2001 03:16 PM
b18bturbo
Aug 19, 2001 09:48 PM
